seibon cf lip
Old Mar 25, 2008 | 09:19 AM
coto's Avatar
seibon cf lip
quick question about the seibon cf lip. i'm planning to replace my oem lip with the seibon but was wondering if anyone knew if it came pre drilled with the holes ready for the install? painting my fog light housings black today and i think th cf lip will look really well.
Old Mar 26, 2008 | 06:23 PM
SD_MR_FIT's Avatar
uh they dont come pre drilled. you have to drill the sides into your bumper.
Old Mar 27, 2008 | 09:25 AM
coto's Avatar
sweet ride.
Old Apr 9, 2008 | 01:13 PM
12o177e's Avatar
yea as stated u gotta drill. with mine, i had to do alot of shaving as well...
Old Apr 14, 2008 | 09:22 PM
TeamStaNceFIT07's Avatar
yeah there is alot of shaved and fittin i have tried to do mne twice now and i still have to do it again to get it right long hard process but it is way worth the hard work.....good luck man and just to let u know its very low and be prepared to drive carefully and possible hurt the lip a lil bit i no i did and i drive the long way around everythin just to get a flat entrance lol
Old Apr 14, 2008 | 09:38 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
I noticed at the track event your lip ate into your fog covers. Its common and its almost impossible to eliminate dude.
Old Apr 14, 2008 | 11:47 PM
SD_MR_FIT's Avatar
thats why you get the hondafittuner.com mugen style lip. that way it will huge the oem lines.
Old Apr 15, 2008 | 01:01 PM
coto's Avatar
thanks for tips guys. so i'm guessing i'm going to go with the mugen style lip off hondafittuner. com. it's gonna look super fresh once it on there. once again i appreciate all the input.
Old Apr 15, 2008 | 01:26 PM
JDMchris.com's Avatar
I run THIS
I personally like the abs dynamics mugen style lip better. The seibon and hondafittuner lips make the car look like it has a under bite.
Old Apr 15, 2008 | 01:47 PM
coto's Avatar
that look pretty fresh it look like the lip that mx6gt89 has on his fit. i dont like how it comes up so high on the sides it look good when its a painted lip but cf might not look that clean. i'm still going for the mugen style.
Old Apr 15, 2008 | 04:34 PM
12o177e's Avatar
damn...my problem as well....
Old Apr 15, 2008 | 06:19 PM
Illusive's Avatar
If you get the ABS ones, it's an easy fix. Dremel with a drum sander and remove as much as you need until it doesn't touch.
Old Apr 15, 2008 | 06:30 PM
Posts in the NUUDE
Blah! Too much work Justin. I just let that ish EAT.
Old Apr 15, 2008 | 06:35 PM
Illusive's Avatar
LOL it's not that much work!!! Like 5 mins MAX!
Old Apr 15, 2008 | 07:17 PM
SD_MR_FIT's Avatar
but wouldnt that stuff melt like crazy. i guess then you would have to hand sand it.
Old Apr 15, 2008 | 07:21 PM
Posts in the NUUDE
I dremeled mine a little. It works fine, just keep the hot plastic off the visible side of the lip. It could warp it.
I just wanted it on. So I put it on. I also made a bracket for the bottom so it wouldnt lift up.
Cat
Apr 22, 2012 05:41 AM
Cat
Mar 15, 2012 06:49 PM
Benggolf
Jun 1, 2009 08:12 PM
Fit of RAGE
Mar 28, 2009 03:15 PM
Mark94
Jul 16, 2008 01:04 PM
