Rubber pad pulling away from carpet
Old Mar 25, 2008 | 01:59 PM
kevjandon's Avatar
The rubber pad on the carpet at the drivers seat has 2" ripple that goes across the rubber pad. It is pulling away and the car has 3,200 miles on it.
Anyone else have this problem?
How did the dealer fix it?
Old Mar 25, 2008 | 03:39 PM
is that like under the floormat area?
Old Mar 25, 2008 | 03:44 PM
Mr.Ball's Avatar
Take it to Honda.Should be under Warrenty.
Old Mar 25, 2008 | 04:41 PM
kevjandon's Avatar
If you remove your floor mats there is a rubber pad on the floor of the driver side only. That is what is pealing up.
I know that it will be covered under warranty, but has anyone had this problem and had it fixed? If so, how did they fix it?
Old May 20, 2008 | 08:29 PM
Sir Robin's Avatar
Mine has a crappy indentation where my foot sits it appeared barely after 5000 miles i took it to the dealer and they said it was normal
Old May 20, 2008 | 08:37 PM
a fit called umeko's Avatar
Smile
eep, this seems annoying. do you have carpet mats in there? That would probably help it from not getting worse. My car has about 2000 miles on it and I would not be happy if this happened, but i'm thinking the mats will protect the carpet and the rubber pad. good luck!
Old May 20, 2008 | 10:53 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
yeah do you have the all season mats?
Old May 20, 2008 | 11:05 PM
Arisenfury's Avatar
Mine has been doing it since a few months of ownership as well. I've just learned to ignore it for the most part. If it gets really bad I'll just get some of the OEM floor mats. If it comes a good portion of the way off you could always try to reglue it or see if you can convince the dealer to replace it under warranty.
Old May 21, 2008 | 11:28 AM
kevjandon's Avatar
Went to the dealer and they tried to convince me that this is happening because I don't have floor mats. I quickly pointed out to them that floor mats are not "required" anywhere in the owners manual.
They offered to pull the rubber mat off and re-glue it down. They will not replace it as it comes with the capet so they would have to re-carpet the whole car.
Juliane
May 13, 2011 01:37 AM
workin9classhero
Nov 29, 2010 11:41 PM
pip_rocks
Jun 14, 2008 04:17 PM
kevjandon
Mar 25, 2008 01:12 PM
Jonniedee
May 18, 2006 09:49 PM
