Quote:
Originally Posted by methodbasic
so are they similar to stock in feel or smoother?
is just as smooth if not smoother than stock with 195/55/15's.
im running 195/50/15's so it's suppose to be a tad harsher
but again, there's no harshness. if you look at my ride height
you'd think it would be pretty stiff because it's about 2" lower.
my picts dont appear like its 2" lower because im running shorter
profile tires. if i run the regular size, the top of the tires will be
slighly tucked under the fender arch.
but the ride is unbelievably butter smooth, and there is plenty
of suspension stroke. plus, with the coilovers, if you need
more stroke for carrying heavier cargo, you can raise it tad, etc.
