Fit Sport at Auto X, need Stock size rim suggestions
Old Apr 21, 2008 | 12:27 PM
ilfit's Avatar
I took my stock 08 Fit Sport to MILW SCCA on Saturday and had a blast!
Needless to say, my stock tires were horrible on the circuit. I was still surprised how my Fit handled at the limit, esp. when my instructor just hit it!
Other than finding a set of stock Sport rims used, what does everyone suggest for getting a set of stock sized rims to use for the track?
I want to stay in the stock class, so upsizing is not an option now.
Thanks in advance,
Rich
Old Apr 21, 2008 | 01:07 PM
Tofuman's Avatar
if you're trying to keep it inexpensive, i would go with rota circuit 8 or something similarly light weight. maybe falken hanabi wheels. they are also pretty inexpensive.
Old Apr 21, 2008 | 06:51 PM
sl0wp0k3's Avatar
nope.
there are other threads on this subject. basically it is really hard to find a wheel that is 15x6, with an offset higher than 49mm. The only one I know of is the Sport Edition D4. other than that, good luck finding an aftermarket wheel that is legal for stock class.
Old Apr 21, 2008 | 09:50 PM
ilfit's Avatar
thanks for the answers here.
I have been having trouble finding the illusive 15x6 wheel. Looks like I will look for a used set of stock Sport rims.
Are there many other stock Honda or Acura rims that measure 15x6? If so, perhaps that could be an option for me as well.
Old Apr 24, 2008 | 10:37 PM
08FitSport's Avatar
What about Rota circuit 10 +45 off set it's 6.5s though.
Old Apr 25, 2008 | 03:45 PM
Sugarphreak's Avatar
Push My Button
I remember you to have an offset of something like 48 or more in order to stay in the stock class.
Best option I saw that came out of the "Great Autocross Wheel Hunt" was some Saturn rims that met the requirements and were lighter...
....and LINK!
https://www.fitfreak.net/forums/fit-...ss-auto-x.html
Old Apr 28, 2008 | 03:42 PM
Skimmer's Avatar
I can recommend the Saturn 'sawtooth' wheels. I've run 4 autocrosses with them now and they work great. Plus, you can't be the dirt cheap price. I paid $100 for all four.
Old May 11, 2008 | 11:27 PM
MINI-Fit's Avatar
Skimmer,
What is the weight of the saturn wheel alone and/or with tire (which tire?)?
The legal rim must be 15x6 for the Fit sport and within a quarter inch plus or minus for offset (+55mm).
Old May 12, 2008 | 01:38 PM
Skimmer's Avatar
MINI: I'll have to get back to you tomorrow on the exact weights as they're written down at home and I don't remember the exact numbers. But I can tell you the Saturn tire/wheel combo is about 2 lbs. lighter than the OEM tire/wheel. This is with a 205/50/15 Kumho V710 R-comp tire mounted on the Saturn wheel. In other words, not a huge weight reduction, but it's something and it's nice for the price.
As for the specs, the Saturn wheels are 15x6 with a 50 mm offset, so they fully satisfy SCCA stock-class rules. This thread has more details:
https://www.fitfreak.net/forums/gaug...heels-fit.html
Old May 27, 2008 | 05:19 PM
mahout's Avatar
You'll want 15x7's with 45 mm offset to mount 195/50x15 sticky tires up front and stock tires on 15x7's with 45 mm offset out back. You can also go with 6mm spacers to effectively have 49 mm offset on your stock whhels for low cost. Just make sure you have 1/2" threads for the lugnuts to tighten on. And of course the stickiest legal tires.
Try to have the front tire diameter a tad less than the rears (no more than 1/4") out back for fastest times with disconnected front antisway bar. Yes, it will oversteer but A/Xers have shown for a long time that controllable oversteering is the fastest way to go. Getting the Fit to rotate in corners so it can exit corners in a straight line from the apex is what you want. The faster exit speeds are the route to winning. The best acceleration is in a straight line not in a curve.
You might want to practice in a vacant lot to acquire the skills to initiate and control the rotation. But you will be quicker.
Last edited by mahout; May 29, 2008 at 08:46 PM. Reason: spacers for less cost than wheels.
2011_Vortex
Jul 14, 2011 04:14 PM
SlcRicer
Apr 6, 2011 12:01 PM
SpOrtSTyleGD3
Las Vegas Community
May 23, 2009 12:51 PM
hyogen
Mar 29, 2008 02:54 PM
carbap
Mar 16, 2008 03:59 PM
