View Poll Results: Should I buy the Infinity Basslink II?
Yes
31.58%
No
15.79%
You Fool .. That Thing Sounds Like Garbage
52.63%
Voters: 19. You may not vote on this poll
Should I? Yes or No
Old Apr 25, 2008 | 01:40 PM
dbcmaster's Avatar
Old Apr 25, 2008 | 02:07 PM
RDS's Avatar
RDS
Senior Member
I thought about adding a Basslink II to my old system in my old car before I had my accident. I say go for it
Old Apr 25, 2008 | 02:09 PM
cavie187's Avatar
There are better options out there.
I see you are liking that site.
Old Apr 25, 2008 | 02:26 PM
dbcmaster's Avatar
Well... best price I found and it's easier to buy em both from the same place.
Old Apr 26, 2008 | 06:42 PM
Injundon's Avatar
a 10" powered bazooka tube would sound better.
Old Apr 26, 2008 | 11:11 PM
dbcmaster's Avatar
Really? I always found those to be crap.
Old Apr 26, 2008 | 11:27 PM
pwnstar's Avatar
are you just looking for somthing that has a amp and sub togeather or you looking for somthing that sounds good as a system? like amp subs ect.?
Old Apr 27, 2008 | 12:42 AM
SD_MR_FIT's Avatar
dude those things are SUPER SHITTY.
Old Apr 27, 2008 | 12:57 AM
Injundon's Avatar
uch better than a basslink in terms of sound quality. Can't compare an inespensive powered sub to a good quality sub with a good amp. As far as space and quality with modeate output, the bazooka's outperform a basslink, or kenwoods powered box any day of the week. an Alpine L.A.T5 or L.A.T 7 would sound better and have more output..but at that price it's kinda rediculous
Old Apr 27, 2008 | 06:43 AM
dbcmaster's Avatar
I'm just trying to get something that doesn't take up much room. If I have to go the separate sub/amp way, I will. Your thoughts?
Old Apr 27, 2008 | 08:03 AM
DagerOne's Avatar
I, and some others who have wanted to do exactly what you're wanting, have been reasonably pleased with the performance of the Audiobahn powered tube subwoofers (do a search for the ATB10AT install thread). Same concept as the Bazookas with easy installation, decent sound, low pricetag, and easy removal or reorientation if necessary should you need the space back temporarily. It also accepts speaker-level inputs, so you wouldn't need to add a line-out converter if you don't wish to do so. I do like the Basslinks as well, but they're a bit more expensive (not significantly so, granted) and I had no intentions of making use of the add-on amplifier capability of the II.
For sound quality, the adage that holds true for engines is also true for your low-end...there's no replacement for displacement, and true quality costs money. If you're wanting to keep it small and inexpensive, though, the tubes are a nice upgrade as long as you aren't thinking that you'll be turning neighbors' heads or the talk of the block. Same can be said of Basslinks.
Old Apr 27, 2008 | 09:01 AM
dbcmaster's Avatar
Yah. I'm not looking to be heard from 6 blocks away. Just want a little bump.
Old Apr 27, 2008 | 09:46 AM
pwnstar's Avatar
LOL... Audiobahn... Audiobahn is garbage never have the true watts thay say sound is not even good. If you want somthing small run Memphis there amps are all true wats, small and sound is awsome just run a 1100d amp on 1 12" M3 it will not take up any room and give you that little bump you looking for..... and then more. but again Audiobahn is really not somthing to look into for car audio, yes thay may be a big name like LEGACY,PYRAMID, sony even just cuz the cools kids all have them and thay sell at wal-mart dosent mean there good.
angryhippie
Oct 4, 2012 07:12 PM
narf
Sep 27, 2011 12:32 AM
FitPilot
Aug 11, 2009 11:11 PM
micknkeef
Apr 17, 2009 02:30 AM
Gbaby2089
Dec 12, 2008 11:01 PM
