what type of tire would i run on 16" Heliums with GF210
Old Apr 26, 2008 | 11:18 PM
pwnstar's Avatar
i am thinking about getting GF210 and i dont want the rims im getting to rub what size tire should i get 205/40/16?
Old Apr 27, 2008 | 12:01 AM
MINI-Fit's Avatar
205/45-16 most likely.
see the last page from
https://www.fitfreak.net/forums/fit-...stions-40.html
Contact Jim@tirerack.com for more info.
Old Apr 27, 2008 | 12:06 AM
SD_MR_FIT's Avatar
yeah without a doubt 205/45/16 = greatness
Old Apr 27, 2008 | 12:17 AM
pwnstar's Avatar
ok thanx guys
Old Apr 27, 2008 | 03:43 AM
soujiro25's Avatar
i have the heliums.. got yokohama's 205/45/16..
it rubs left rear corner if two passengers.. or somewhere i think over 170 lbs in the rear... and if going over slight hills at 50 mph greater.. or on street if big dip.. can rub easily.. this again is all with weight in the back.. with less weight can still rub.. but not as easily.. if you got no passengers or cargo in the rear.. it drives fine.. the standard shock has poor recoil with sustained weight.. with weight in the car, the rear bottom drops alot... test it.. drive for 10 mins.. over some dips hills with 3 people in back.. you get out and measure it... it keeps pretty low.. and the konigs offset so low.. guess they're saying 45 or higher for less chance of rubbing.. going to try to change out rear shock later.. think they say falken azeni's wall tends to be less square at the 205/45 size.. so maybe check out that brand.. goodluck..
Nio4
Jul 2, 2013 10:45 PM
AtticusFit
Oct 11, 2012 10:16 AM
Theos92vr4
Mar 12, 2012 01:32 AM
AtticusFit
Jun 21, 2008 12:55 AM
hiphapa
Jan 23, 2008 10:44 PM
