Sponsored by:
Sponsored by:
Want to replace the wipers...
Old 12-22-2011, 10:08 AM
Blackbeard's Avatar
Thumbs down Want to replace the wipers...
I am jealous of the Civic wipers that sweep up from the middle and clear to each side in a scissor motion. This leaves the uncleared spot behind the rearview mirror where it doesn't matter. They also use two normal sized wiper blades.
Our cars with the gargantuan 28" wiper blade and the tiny 14" wiper blade limits replacements, and leaves muck to right of the passenger's view.
Have not found any good winter blades in a set that I can install, and most of the crappy blades that come in both these sizes are worse than the factory blades and not made for the snow and ice.
Old 12-22-2011, 08:11 PM
illest_GE8's Avatar
Debo'ed Avatar FTW!!1!1!
its better keepin the stock blades because you can jus replace the wiper inserts. saves money
Old 12-23-2011, 12:54 AM
smaglik's Avatar
agreed. dirt cheap, and work pretty well.
Old 12-24-2011, 02:36 AM
Blackbeard's Avatar
Thumbs down Yes, but...
The factory blades and inserts aren't winter blades which was my question. Not as cheap if I have to replace them twice as fast after running them across ice on the windshield...
Old 12-25-2011, 12:50 AM
dll932's Avatar
Good luck finding 14" blades!
Old 12-25-2011, 06:33 AM
Cat's Avatar
Cat
Cat is offline
After I had the inserts replaced, they seem to work much better but yes those farting wipers have always been an issue.
Old 12-25-2011, 04:39 PM
einstein77's Avatar
I go to my local Advance Auto and get inserts that will fit dimensionally (width, thickness, etc.), but not in length. I use a hack saw to cut to the proper lengths. Comes out fairly cheap and allow me to use better, or at least, try different material blades.
Old 12-25-2011, 08:55 PM
AcousticAudio's Avatar
That's why you don't run your wiper blades over the ice on your windshield.. I endure edmonton winters and have had no issues with my factory wiper blades. Change the inserts every once in awhile and its all good.. for 10$ a set you can't go wrong. Try scraping your windshield before getting in the car
Old 01-03-2012, 12:07 PM
Blackbeard's Avatar
Smile Thanks...
For the car obsessive sermon...maybe I should envelope my car in a hot air bubble to keep the atmospheric elements off it...or after scraping...hook up a hair dryer to my outlet to melt any pesky little remaining ice chunks...
Here is what I was looking for...actually found on JC Whitney who is giving free shipping for anything...with code JCW2012.
All the application guides say to use the 13" Trico Winter Blade for the passenger side...they were cheaper on Amazon...and combined together for free shipping...$11.23 (13") + $18.59 (28")
http://www.amazon.com/gp/product/B000BQ6YM6
http://www.amazon.com/gp/product/B0002JN3K8
TRICO WINTER BLADES
As the first manufacturer to develop winter wiper blades in 1953, TRICO set the standard for snow country performance. TRICO Winter blades feature a protective rubber boot to help prevent snow and ice from clogging the blade. This allows it to maintain even pressure to provide a clean wipe and enhance driving visibility. Winter blades have a riveted design for extra durability. Their extra-thick, rugged OEM metal superstructure provides superior strength, and the pre-attached universal adapter fits 95 percent of vehicles directly. TRICO Winter blades are available in lengths of 11" to 28".
Old 01-03-2012, 01:12 PM
Those Trico winters are good blades, I've used them on other cars. Interesting to see they list them for the Fit. Wonder how the 13" would work?? I'll bet just fine.
carid
12-16-2015 03:20 AM
12vltfrk
12-02-2010 12:06 PM
stenoienpm
12-05-2008 04:24 PM
Gordio
09-10-2008 03:43 PM
FikseRxSeven
01-12-2008 03:30 PM
Quick Reply: Want to replace the wipers...
