Climate Control Switch Bulb and Audio LCD Failure Problem
Hi All,
I have 2012 year Honda Jazz with Manual Climate Control switch and now I have problem with the Bulb as you can see below image.
So I opened to check the bulb and I check with tester, I think the bulb has problem.
Where can I find this bulb?
And I also have problem with Audio LCD, the portion where the time indicator located is blurred.
I also opened it and I think the LCD itself has problem.
I already visited Honda but they said they have to pullout the unit and send it to distributor to check and the sad thing is it would take around 45 days.
So if I can find the Parts on the web, I would rather buy the parts and replace it by myself.
I was trying to search on the web to find the Climate Control Bulb and LCD for Audio. But I could not find.
Please help me to find these parts.
The bulb is part number - 79555-TF0-003. You will need to order from dealer. To check further swap it out with one of the bulbs in the other controls. They are the same.
The time display problem will likely need to be repaired by an audio technician.
