Pls help! problem with rivet when installing sports pedals!
Old Dec 3, 2008 | 08:43 PM
pizzicato's Avatar
This is my first experience with a rivet tool and I did something stupid.
I just got done installing manual sports pedals but I messed up one of the rivets. It's sticking out a little bit! I'm not sure if I should mash it in with a hammer. This would be the easiest option. Do you think I'd break the rivet? Are rivets strong...? I have absolutely no idea.
Would it be possible to remove the rivet and reinstall another one? The problem with this option is that I don't have anymore rivets and I'm not sure of the size of the ones that I used as they came with the OEM sport pedals...
Any help would be greatly appreciated!
Old Dec 3, 2008 | 08:45 PM
solbrothers's Avatar
drill it out?
Old Dec 3, 2008 | 09:24 PM
Satchel's Avatar
Agreed...drill bit the size of the rivet body (not the head) and drill it out...use a fresh one.
Old Dec 4, 2008 | 07:27 AM
neteng101's Avatar
You'll have to drill it out. Rivets are available, but finding one with a black looking front is the harder part. What I've seen is chrome-ish looking, so that new rivet would stick out like a sore thumb.
Old Dec 6, 2008 | 12:00 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
drill it.
and if you don't have any rivets left over. you can always
get some at Home Depot or Lowes.
Old Dec 6, 2008 | 07:56 PM
pizzicato's Avatar
It doesn't stick out as much as I initially thought. I'm just going to leave it alone. I think I might make it worse by trying to fix it!
Thanks for the help...
Old Dec 6, 2008 | 10:56 PM
neteng101's Avatar
Is it loose or firmly in place? If its holding, you could just sandpaper/file off the excess carefully.
Old Dec 6, 2008 | 11:05 PM
kylerwho's Avatar
spoon fed
just take a center punch and gently hit the top of the rivet with it. this will force the rivet farther into the pedal. rivets are strong so no worries about breaking it.
kloopon
17
Mar 13, 2013 06:24 AM
neteng101
Oct 18, 2008 10:08 AM
GD3-Fit
Jun 14, 2008 10:03 PM
bkgraham33
Feb 21, 2008 12:17 PM
way2slo
Sep 10, 2007 04:51 PM
