Rear bulb fuse
Old Dec 21, 2008 | 01:18 AM
reako's Avatar
My rear lights died!!
I replaced my license plate bulbs with LED 194's tonight. Everything was fine for about 10 minutes then all my rear bulbs went out. I tried fuse numbers 1 and 5 (10A) but they are fine. One of the 30A fuses looks a little off, but does anyone know for sure if there is one fuse that controls all these? The owners manual explains every other fuse except for the rear bulbs. Thanks.
Here are the 194's I used:
194 Size Car LED Bulb
Old Dec 21, 2008 | 05:42 AM
713_fit's Avatar
are there only one or two bulbs in that license plate area?
Old Dec 21, 2008 | 10:04 AM
reako's Avatar
Two, plus my taillight bulbs are out. The brake lights still light up if you hit the brakes though, and everything else I checked still works (horn, locks, reverse lights, all interior lights etc.). If I don't figure out which fuse it is by tomorrow, it will have to go to the dealer! Help!!
Old Dec 21, 2008 | 10:26 AM
kylerwho's Avatar
spoon fed
what about the driving lights?
Old Dec 21, 2008 | 10:28 AM
reako's Avatar
Good call, I just checked and you're right; those are dead as well.
Old Dec 21, 2008 | 11:46 AM
Virtual's Avatar
It shouldn't be fuses 1 or 5. They are for back up lights (They light up when in reverse gear).
You mention that a 30A fuse looks "a little off". Which one is that?
I would start by checking fuse #28.
If that doesn't solve it then it's a one by one check of all fuses until you find it. Use a continuity tester if needed.
Recheck your LED bulb installation (possible short).
Hope that helps.
Old Dec 21, 2008 | 12:16 PM
713_fit's Avatar
take the LED out
put back the regular bulb out
and get it warranty and try again =D
hahaha
Old Dec 21, 2008 | 12:26 PM
Virtual's Avatar
take the LED out
hahaha
That would be wrong and I don't think that fuses are covered by warranty.
Old Dec 21, 2008 | 12:42 PM
reako's Avatar
Hope that helps.
I had to take the wife's car to work today because of this, so I won't get to troubleshoot again until later tonight, but if I had to guess I would say that the 30A that looked different from all the rest was either the front wiper fuse (56) or ABS/VSA (58) because I remember the fan blower (57) kicking on during troubleshooting late last night. The fuse just....may always look different than the rest, I was getting desperate.
I'll check 28 tonight, I really hope that that's the right one, can anyone please confirm this? That would be great!!
If that's accurate, it would make things a lot easier if the manual included the fact that it's not just for "Headlight main" (as labeled), but also for "Tail light main"!! There are countless other fuse descriptions of which I'm assuming you must be a Honda certified technician to understand: ACG, LAF, IGP, STS.....with no mention anywhere in the owner's manual what any of it stands for......stupid!!
Thanks for the help thus far..
Edit: Wipers still work, so I'm not sure what's up with that fuse.....I'll do some more troubleshooting tonight to be sure that fuse is supposed to look the way it does.....I'll also swing by and pick up a couple 20A fuses (crossing fingers anticipating that #28 will be the culprit!).
Old Dec 21, 2008 | 11:35 PM
reako's Avatar
Fuse #28 is in tact....that sucks!! I'm running out of options before I'll be forced to take it to the dealer tomorrow morning....all for a stinkin' fuse!?? Any more ideas guys??
Old Dec 22, 2008 | 01:37 AM
reako's Avatar
Fuse #29 was it!!! Thank you HONDAMATIC!!!! FYI the manual states #29 is "Small light", this fuse controls the front and rear driving lights, and HONDAMATIC just saved me a trip to the dealer, thanks again for responding so quick!!
Old Dec 22, 2008 | 01:43 AM
HONDAMATIC's Avatar
rep for me? hint hint* haha
yeah that one drove me nuts too.. i know all too well how you feel.. it happened to me on the way to walmart one night and i had to drive home from there without getting pulled over.. i didnt even get to go to the store!
Old Dec 22, 2008 | 10:54 AM
JDM_DOHC_SiR's Avatar
Thumbs up
Good find!!.. Rep for you then!!
Old Dec 22, 2008 | 07:33 PM
reako's Avatar
I ended up having to get the fuses from the dealer, called around to autozone, NAPA, etc. and know one had them! Paid $3.00 for two 10A fuses after tax, popped one in there and all is good with the world once again!
Old Dec 22, 2008 | 09:52 PM
HONDAMATIC's Avatar
yay! got lights again!!
i find it really unusual that the GD does not have spare fuses.. looks like the GE doesnt either.. unless im looking in the wrong place
Old Dec 22, 2008 | 11:59 PM
reako's Avatar
I couldn't even find the chip puller which is supposed to be under there somewhere!?
omygod711
Mar 13, 2019 07:03 PM
hqly2001
Apr 23, 2018 08:21 PM
rohanks
Oct 11, 2013 02:43 PM
battouter
Oct 11, 2013 02:05 AM
reako
13
Feb 9, 2009 05:29 PM
