15" vs. 16"
Old Jan 13, 2009 | 04:46 PM
L15A's Avatar
15" vs. 16"
I know a thread similar to this exsits..but not all exactly the same; I just read it...
...anyway, thinking about getting aftermarket rims. What do you guys think about 15" vs 16" I know that 16"s look better...I think most would agree...but what are the benefits of 15"s??
I mean, if you have a 15x6.5 vs. 16x7 rim and they both have a 185/195 width, fuel efficiency would be the same right? The 16" would obviously have a little bit of a better feel on cornering with the shorter sidewalls. So with that said, why would anyone get 15s??
Old Jan 13, 2009 | 05:00 PM
mikejet's Avatar
You could save a couple bucks? I'm wondering too since I've picked the rims I'm getting. The all white Konig Countersteers.
I don't know which size either!
Old Jan 13, 2009 | 05:05 PM
L15A's Avatar
yeah...exactly...and not that much of a difference either. Take Volks for example. Even though they're pretty pricey to being with, at Retail, the difference between a 15" and 16" is only 50 bucks! And the cost difference between the same tire (Bridgestone Potenza RE760) is only about 20 bucks a pop.
If this is true...then everyone should just go with a 16" right? (assuming the $ diff is considered marginal to the consumer)
Old Jan 13, 2009 | 05:07 PM
Tork's Avatar
16's to many people look better.
Advantages to 15's
* depending on wheel 2-5 lbs lighter (vs 16) = less rotating wt.= faster accel
* weight is closer to the center of hub see above
* more tire sizes= better tire selection
* replacement tires likely cheaper
Old Jan 13, 2009 | 05:17 PM
L15A's Avatar
15" Volks are about 10.4 lbs
16" Volks are about 12 lbs.
so...a bit lighter...but enough to make a "difference" that's up to you to decide...me, no.
More tire sizes? (TireRack)
205/55/16: 158 tires
205/50/16: 44 tires
195/60/15: 63 tires
195/55/15: 34 tires
And like I said about tire pricing differences..they're roughly about 20-25 different. over 40,000 miles...not that big of a difference.
Old Jan 13, 2009 | 11:17 PM
projekz's Avatar
You should also account for the difference in tire weight. The thicker sidewall on the 15s makes the tire heavier than the 16 inch. Something worth considering! I say just get what you want look wise or price wise.
Old Jan 14, 2009 | 12:45 AM
L15A's Avatar
you're right, 15" tires are heavier than 16" tires with the same width.
Old Jan 14, 2009 | 01:34 AM
iheartJDM's Avatar
i honestly think it just depends on the wheel itself (offset,width, etc) and the ride height of the car. Some 16's are lighter than 15's.
a set of SSR Type C's in 16's were lighter than 15" Advan RGII's when i picked them up by hand to compare
Old Jan 14, 2009 | 08:05 AM
hanzo's Avatar
Tires are probably going to get cheaper on 16" since most cars nowadays comes in 16" plus.
Old Jan 14, 2009 | 08:30 AM
Virtual's Avatar
I don't think that's true. 12" is cheaper than 13" which is cheaper than 14" etc. The "most popular" size doesn't seem to affect that.
Old Jan 14, 2009 | 09:52 AM
iheartJDM's Avatar
i got my kumho ecsta's in 205/45/16 for $195 shipped
Old Jan 14, 2009 | 09:58 AM
hanzo's Avatar
Well I guess at least the 16" you have more tire choices, I know when I looked at 15" there aren't that many tire options.
Old Jan 14, 2009 | 03:43 PM
SRLNCLT's Avatar
I'm not sure if I'd go with 15's. To me on the base Fit, they look too small. Also, I don't know what you plan on doing to your Fit but a performance wise I doubt you'll notice the 10 lbs you save in weight. The mpg, well, I guess but 16's looks better so stay with 16's!
Old Jan 14, 2009 | 04:26 PM
Import Al's Avatar
All the pros/cons above are true. I'd agree that 16"s look better.
But if you're going for max lateral G's (handling) & better acceleration I'd find a light 15x7 (Rota, SSR, Motegi, Konig) & sticky 205/50 tires like Azeni, Nittos etc.
I think Spoon knows a thing or too about this subject lol.. 1.09 G's grip on 185/50 Advans & 15x6.5" Spoon SW388 wheels.
Spoon Honda Fit - Featured Cars - Honda Tuning Magazine
Old Jan 14, 2009 | 06:03 PM
Virtual's Avatar
They may know that they are doing but that is a first gen Fit. This section is about the 2nd gen Fit. Quite different when it comes to wheel size.
Old Jan 14, 2009 | 06:42 PM
Import Al's Avatar
True true.. my point was that dimensions & suspension-wise, not much drastic has changed from GD > GE so it would be logical to assume a light, wide 15" wheel would be good for handling & acceleration (by lowering effective FD ratio) like on the Spoon FiT.
There are lots of light 16x7"s out now though, & the performance difference would be negligible so just pick what size you like.
sabawballs
Oct 30, 2014 12:16 PM
EMC2
Apr 26, 2012 05:18 PM
sonicsc1
Nov 1, 2009 10:13 AM
maccoy77
Nov 6, 2008 12:43 AM
PHATFLIP
Jul 29, 2008 12:59 AM
