Shifter: Higher but shorter
Old Feb 17, 2009 | 01:06 AM
No_Skillz's Avatar
So I'll admit: I promised myself I wouldn't mod the fit so I don't know much about the available aftermarket. I eventually broke down and now I'm looking to get a short shifter.
I want something that is at least as tall as stock (if not a tad taller) but significantly shorter throws.
After some research, I've found some possibilities like H-Fit (although I'd feel retarded if I spent $70 on a few glorified washers and a nut)and Skunk2 ($100+ for a metal stick? talk about self-inflated sense of value) although I would still like some more input.
Old Feb 17, 2009 | 08:34 AM
BakedCookies's Avatar
The H-Fit will totally fit your needs. I have it and love it. Its a lot nicer than just washers and a nut.
Old Feb 17, 2009 | 12:25 PM
No_Skillz's Avatar
Do the base pieces on the H-Fit actually raise the shifter assembly?
With that said, is it possible to raise it more with the addition of washers, at the same time adding a nut to tighten the extension piece against, resulting in an even higher and shorter throwing shifter?
Old Feb 17, 2009 | 01:09 PM
Yes they raise the shifter assembly so the shifter extension has enough clearance against the floor of the car. I don't think you could raise it much more without running into issues with the center console clearance.
Vash
Jan 13, 2020 02:44 PM
cptjon
May 20, 2015 07:32 PM
CrystalFiveMT
Mar 6, 2010 10:07 AM
xanatos
Aug 26, 2008 11:06 AM
sethne
Jul 10, 2008 09:58 AM
