Real DRL
Old Feb 25, 2009 | 06:14 PM
VaJim's Avatar
Real DRL
....bear with me on this. My only experience with Daytime Running Lights is on my Chevy Silverado. There you do nothing. Once it turns dark your instruments lights come on (sensor on dash). Your headlights have been on all along. With the Fit you get a 'sorta' DRLs (ok), but you still need to turn on your 'real' headlights once the sun goes down. Do I have this right. Note complaining, just want to make sure I understand the operation.
Thanks!
Old Feb 25, 2009 | 06:20 PM
SheepNutz's Avatar
Yeah, if you headlights are off, you'll just get the dim DRL. There are no sensors, so when it gets dark, you'll have to flip on the headlights.
Old Feb 25, 2009 | 06:22 PM
VaJim's Avatar
...thanks
Old Feb 25, 2009 | 06:56 PM
lilaznphatboy's Avatar
https://www.fitfreak.net/forums/2nd-...ng-lights.html
on that thread someone posted on how to disable your DRL if your interested
Old Feb 26, 2009 | 02:39 PM
Olyar15's Avatar
Thanks!
Those are not DRLs. True daytime running lights are NOT the normal headlights, and are not designed to improve YOUR visibility. They are designed to make your car more visible to oncoming traffic.
DRLs are usually the highbeams set to a reduced voltage (and therefore a lower light output) that come on whenever the engine is running and the handbrake released. They are not a substitute for the headlights at night. I suspect that your Silverado have automatic headlights, that a lot of luxury vehicles have. Again, these are not the same as DRLs. Now, your Silverado may also be equipped with DRLs, but these are separate from the automatic headlights.
NotMyName
Sep 8, 2014 09:57 AM
fujisawa
Sep 26, 2012 11:37 PM
ineedareed
Jan 31, 2008 11:30 AM
RobVT
Jan 31, 2007 08:36 PM
tiF adnoH
Jun 6, 2006 05:45 PM
