Rear Washer Spray Intensity?
Old Apr 2, 2009 | 11:17 PM
Lucky Devil's Avatar
I hadn't really run the rear washer on my 2009 until today. It appeared to get enough water on the rear window to wet it down, but it seemed more to drool down than really spray like the front does. It appears from the diagram that there is only one pump and resevoir (in the front of the car) that feeds the front and the rear washer. If this is the case it would make sense that the pressure is reduced all the way in the back. What's your rear washer like?
Old Apr 2, 2009 | 11:55 PM
reako's Avatar
That's exactly how I would describe my rear washer performance... Cool diagram btw...I need to explore that site.
Old Apr 3, 2009 | 12:16 AM
boojum's Avatar
Mine works just fine. Have you refilled your tank? If you did, could there have been impurities in what you refilled it with? My limited understanding of hydraulics says that the pressure would not drop much, if any, unless there is a soft line carrying the fluid which would be expanding to absorb some of the pressure.
I'd check the line/nozzle for debris.
Just a guess.
Cheers
Old Apr 3, 2009 | 12:41 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
same here also.
Old Apr 3, 2009 | 01:24 AM
peg_leg's Avatar
mine drools too
Old Apr 3, 2009 | 08:55 AM
minnemike's Avatar
I would assume drooling would be the design. It uses gravity as it points down... If it had pressure, it might shoot most of it off the window.
Old Apr 3, 2009 | 09:20 AM
wpyeo's Avatar
my RS drools @ the rear also. i supposed it is what it is intended to be..
Old Apr 3, 2009 | 09:28 AM
Thanks for all the responses! I just wanted to make sure I'm not the only one who drools.
Old Apr 3, 2009 | 04:45 PM
Alpha Zero's Avatar
Yes it's supposed to only drool. My RSX also drooled as did my Civic Hatchback.
Old Apr 3, 2009 | 04:59 PM
Fat Ping Cat's Avatar
boooo majestic honda
Old Apr 3, 2009 | 05:42 PM
Hondafrk's Avatar
Boo? I order from them all the time and have had great service always.
Care to elaborate?
Old Apr 3, 2009 | 09:13 PM
Cat's Avatar
Cat
Typical for the Fit the back one drools and the front ones fart!
Cat :x
Old Aug 13, 2010 | 12:44 AM
J3SS13's Avatar
LOL
I love how u guys describe it as "drools" but yeah mine does too and it is a Jazz. So no worries pal, it's completely normal
Old Aug 13, 2010 | 07:30 AM
specboy's Avatar
Drooling here. If it sprayed, I would think it would get sucked/blown away from the rear window and be totally useless.
~SB
Old Aug 13, 2010 | 07:49 AM
Type 100's Avatar
Yep it's the same patented drooling action on the GDs. Hahaha!
Ever since I had my rear hatch replaced after a collision two years ago, I've had this two-second delay between my initial twisting of the wiper stalk and actually getting any "drool" back there. FYI
This happens regardless of how much washer fluid is in the reservoir, so I'm guessing something to do with the drool lines going to the rear. No biggie.
Old Feb 2, 2013 | 08:09 AM
jeuda's Avatar
anyone tried to change it to another? I searched, seems like the CRV are using spray type on their rears....
Old Feb 2, 2013 | 09:17 AM
jeuda's Avatar
Old Feb 2, 2013 | 12:09 PM
Dwalbert320's Avatar
Mine's a drooler at best. Spits, spouts, spats!!!
Old Feb 2, 2013 | 02:00 PM
hogwylde's Avatar
At best......mine dribbles.
Old Feb 2, 2013 | 09:33 PM
MTLian's Avatar
Mine spurts outta there like... well... It spurts! Sometimes I get the impression the spray misses the windshield totally it's so strong, I might try and check it and fiddle with is sometime.
