Rear Washer Spray Intensity?
Old Feb 3, 2013 | 12:34 AM
Lance's Avatar
sprays fine
mine sprays fine every day for 5 years. Even at highway speeds it sprays the whole rear window.
Old Feb 3, 2013 | 11:19 AM
mkane's Avatar
Our GD sprays, the GE's like a shower. We never use tap water as our is hard like a rock.
Old Feb 4, 2013 | 09:24 AM
SilverbulletCSVT's Avatar
Originally Posted by specboy
Drooling here. If it sprayed, I would think it would get sucked/blown away from the rear window and be totally useless.
Mine's a drooler also but works fine, doesn't over soak the window and gets the job done. Like you say if it sprayed it would be useless, it would then be a license plate washer instead.
_
Old Feb 5, 2013 | 09:12 PM
gkitf16's Avatar
Yes, I too have the drool issue of the rear end . Almost looks retarded. Tried moving the nozzle a bit with a sewing needle but there's a very narrow angle to actually hit the glass. If moved too far outward, shoots right past the glass. BTW the sewing needle of the right gauge works great to adjust the front sprays.
Old Feb 8, 2013 | 07:26 PM
Colincarguy's Avatar
I get more of a spray on mine, but i use if often so the line may have less air in it then everyone else on here.
Old Feb 13, 2013 | 01:12 AM
jeuda's Avatar
Saw the honda CRV has check valves.... can we install that along the supply line?
Look at the white/black valve!
hogwylde
Jan 21, 2025 09:50 PM
gsarmedic
Jun 10, 2014 08:53 PM
jeuda
Mar 2, 2014 11:32 PM
sbguy78
May 13, 2012 10:41 AM
girkabob
Mar 17, 2011 11:31 AM
