OEM visors scratch easily!
Old Apr 22, 2009 | 07:49 AM
lxwhite's Avatar
I just installed the OEM window visors recently and after wiping it dry when it got wet from the rain, I already see lots of fine hairline scratches. Even me just wiping off some smudge with my finger seems to leave a few fine scratches too.
Has anyone else with the visors found the same problem?
And is there anything I can use to get rid of the fine scratches or cover it up or anything...?
Cheers in advance everyone
Old Apr 22, 2009 | 08:03 AM
BakedCookies's Avatar
any type of light polishing compound will remove those scratches. I recommend 3M brand.
Old Apr 22, 2009 | 09:29 AM
mikejet's Avatar
Mine have a ton of very small scratched from when I first put them on when I wiped them down with Windex and a paper towel. You only see them up close so I don't care.
Old Apr 22, 2009 | 10:23 AM
jinjinweiwei's Avatar
get some scratch X
Old Apr 22, 2009 | 03:29 PM
yah, scratchx and a soft foam pad.
and wax/seal afterwards.
Old Apr 22, 2009 | 03:33 PM
qbmurderer13's Avatar
Obviously if you wipe it off with just plain rain water it will scratch. Water alone wont get rid of the dirt that your scraping across the visor with the towel.
Also using an abrasive paper towel will obviously scratch it. Clean with isopropyl alcohol and a microfiber towel only.
You just have to learn to properly care for these. Any abrasive like a polish or plastx is too strong for the visors. Just keep them sealed with a synthetic sealant and wash them correctly. Dont use plain water, windex, or paper towels...
Old Apr 24, 2009 | 06:45 AM
lxwhite's Avatar
Hmm any specific sealant you'd recommend?
Old Apr 24, 2009 | 08:57 AM
mikejet's Avatar
On a side note my hood deflector has ZERO scratches and I've used paper towel on that. Must be a higher grade plastic.
No big deal. They work and you have to look really close to see the scratches.
Old Apr 24, 2009 | 07:48 PM
Cat's Avatar
Cat
Even the Mugen ones get fine scratches and I only use car soap and microfibers to clean and dry.
Cat :x
jy1129
Jul 5, 2015 02:25 AM
Sean Passmore
Jan 11, 2015 02:49 PM
phuccer
Jun 8, 2010 09:13 AM
billmus86
19
Dec 14, 2009 10:14 AM
YA2_user_GD3
Jan 31, 2009 08:33 PM
