iPod Version 3.0 OS -- Don't Install It!
Old Jun 19, 2009 | 08:16 PM
cruzitude's Avatar
Exclamation iPod Version 3.0 OS -- Don't Install It!
WARNING: If you're an iPod Touch user, the new 3.0 firmware makes your device incompatible with the Honda factory iPod integration (BMW too, so I've heard). I learned this the hard way ... although I can play music, I cannot select Playlists, Artists, or Albums. I'm trying to revert to 2.1.1 but no luck yet
{edit: Removed reference to iPhone}
Old Jun 19, 2009 | 09:29 PM
Revelie's Avatar
woah! thanks for the heads up! I was downloading the update now. I guess ill hold off.
Old Jun 19, 2009 | 09:47 PM
Holy_Fit_Batman!'s Avatar
I got my 3GS today, and of course it has OS 3.0. I went to the car after reading this, and although it initially took some time for the words to show up, everything works perfectly like before. Don't know what you did^
Old Jun 19, 2009 | 10:16 PM
cruzitude's Avatar
Good to know ... Maybe the hardware difference with the 3G S allows it to work. I have a 2nd gen Touch and it doesn't work with 3.0 even after trying a complete restore on it. On a different forum I saw a guy having a problem with his BMW and iPhone 3G with the 3.0 OS. So, unless you have the new iPhone that came out today, maybe stay away from 3.0.
Old Jun 20, 2009 | 12:26 PM
iibbmm's Avatar
I upgraded my 3g to 3.0 and it works perfectly in the Fit, just like before.
Old Jun 20, 2009 | 12:51 PM
Ciggy's Avatar
You can easily restore the iPod to the older firmware. Learned all of this when I jailbroke my iPod.
Download the firmware you would like to use then in Itune shift+click the restore button and navigate to the firmware you downloaded let it restore and your now back in business with the old firmware.
Old Jun 20, 2009 | 03:56 PM
Checked with the wifeys 3G with 3.0 and that works fine too.
Old Jun 20, 2009 | 08:16 PM
zakurie's Avatar
I have used both a 3G and 3GS, both with OS 3.0, in my Fit and both were perfectly.
The OP should do a restore through itunes.
Old Jun 20, 2009 | 09:35 PM
awptickes's Avatar
My phone works fine on my father's USB thingie in his Sport. I have an iPhone 3G that I use for development.
My mother's BMW (328i 2008) has had no problems with either my 3G on every single 3.0 beta, and her new 3Gs.
I don't know what you're smoking, it's worked fine since 3.0 Beta 4 (The first version I tried.) Sounds like something else went awry.
Old Jun 20, 2009 | 09:37 PM
awptickes's Avatar
Mods, please lock this thread, as it's just spreading fear and misinformation. Dunno what OP is up to.
Old Jun 20, 2009 | 10:14 PM
jaydubz79's Avatar
+1 there are no problems with the firmware and the USB integration in the Fit. Works just like the previous OS
Old Jun 20, 2009 | 10:54 PM
SheepNutz's Avatar
Works fine for me as well, 3.0 on a 3G S and 3G.
Old Jun 20, 2009 | 11:11 PM
cruzitude's Avatar
True, I don't have firsthand knowledge about iPhone performance with 3.0 -- my own experience with my 2G Touch is real and I was including what I had read from other users in another forum about their iPhone experience with 3.0. I'm glad for iPhone users who are not having a problem, but it most certainly is a real problem for the Touch (and that part ain't misiformation). I know iPods and iTunes quite well, and I can tell you firsthand that my Touch no longer functions with my Fit after installing 3.0, and doing a complete factory Restore twice now.
As far as downgrading firmware, I know all about the Shift-Restore trick, but all I get is error (20), so it seems I'm stuck at the moment.
As far as what I'm "up to", I was hoping to alert fellow Fit users to a problem that is really pissing me off and didn't want others to experience the same. I've edited my original post to remove all reference to the iPhone, sorry for the alarm to iPhone users.
Old Jun 21, 2009 | 09:12 AM
SheepNutz's Avatar
Going up in firmware (to a newer version) is easy with the shift+restore. Downgrading firmware won't work as easily. Here is a link on how to do it, but it requires jailbreaking: [DOWNGRADE] Downgrade iPhone 3G 3.0 to 2.2.1 - Hackint0sh
Old Jun 26, 2009 | 06:55 AM
mchoffa's Avatar
i upgraded my old first gen ipod touch to 3.0 and everything works fine with my navi
Old Jun 26, 2009 | 08:46 AM
awptickes's Avatar
You need to watch the way you phrase things then. It appeared to me, and the casual observer that you were declaring no 3.0 device would work, which is not the case.
Have you resolved the problem?
If you open a support ticket with Apple, they'd be more than happy to assist you. Might even want to try your local Honda dealership.
If that fails, I'd be more than happy to help you.
Old Jun 26, 2009 | 02:57 PM
cruzitude's Avatar
If you look you'll see that I have since revised my initial post and applogized for any confusion caused to iPhone users. This seems limited to iPod Touch, and perhaps the non-Nav head unit since someone above reports no trouble there with a Touch.
On the Apple forum you'll see many others with this problem, mostly BMW but also Lexus, Mercedes, and Honda, as well as Denon, Bose, and other accessory manufacturers. So it definitely is a problem with 3.0, though perhaps not under every condition. Consider yourself lucky.
I have since resolved this by going back to 2.2.1 by putting the Touch in DFU mode and doing a Shift-Restore.
Old Jul 29, 2009 | 08:35 AM
thelouisguy's Avatar
Here is a link to older firmwares if you do have a problem. If you do not, disregard this link.
iPod and iPhone Firmware Download
Kingfisher
Jul 30, 2011 10:19 AM
rel_90806
Oct 22, 2010 11:15 PM
Tigerman50
May 29, 2010 09:50 AM
dcoxsey
Jan 27, 2009 07:18 PM
drknife
May 6, 2006 01:07 AM
