Bottom intake grill removal questions
Old Sep 29, 2009 | 08:15 AM
Spacecoast's Avatar
I received the poly mesh material yesterday in order to perform the mod to protect the A/C condenser unit. When I was looking at the bottom intake grill, basically just looking it over and contemplating on how to do this, I noticed that one of the vertical grill slats has already broken away from the main frame section. Wow, this is really a POS grill. Does anyone know how to remove this? Are there clips or screws holding this grill in place? Does it disconnect from the front bumper by being pushed in and removed out through the top? Thanks
Old Sep 29, 2009 | 08:35 AM
EggHead's Avatar
I tryed to take this off as well, and i think you have to take the bumper off because it feels like there are two or three plastic locking bolts that hold it in place at the top. I took out two that were at the bottom but when i went to pull the grill out the top would not budge....
Old Sep 29, 2009 | 09:36 AM
Committobefit08's Avatar
Here guys see the diagram...
Hope this helps.
Find Honda Parts and Honda Accessories by Car Model - Bernardi Honda Parts and Accessories
Old Sep 29, 2009 | 04:23 PM
Shockwave199's Avatar
If you did a quick search here, you'd find this thread-
https://www.fitfreak.net/forums/2nd-...l-removal.html
You don't need to remove the grill itself to do the job, although it would make applying the mesh easier. Good luck- it's worth it.
Dan
MeTaLoFeArTh
Apr 17, 2012 07:50 PM
majik808
Oct 18, 2011 08:49 PM
Spacecoast
Oct 8, 2009 10:35 PM
iKONA636
34
Mar 13, 2009 12:08 AM
fitfit
Mar 31, 2007 01:19 PM
