GE alignment OEM specs.
Old Oct 25, 2009 | 11:31 PM
Fitcious's Avatar
Does anyone have the OEM Specifications for the GEs alignment? I want to get it aligned and want it to follow through with the OEM specs. I am not going through dealer...and im getting aligned cause i lowered my car. thanks.
Old Oct 26, 2009 | 12:14 AM
k20a298ek's Avatar
you won't be able to align to oem specs anyway
Old Oct 26, 2009 | 12:34 AM
mike2100's Avatar
Originally Posted by k20a298ek
you won't be able to align to oem specs anways.
With camber/toe kits yes he will.
Any decent alignment shop should have a database with the factory alignment specs, unless the GE8 is too new still.
Old Oct 26, 2009 | 12:39 AM
Fitcious's Avatar
so all i have is eibach lowering springs...prokit...so does that mean the shop cant do OEM specs?
Old Oct 26, 2009 | 12:44 AM
mike2100's Avatar
How did you come to that conclusion based on what was posted?
The only adjustment that can be made from the factory is front toe. Front camber and rear toe/camber require shim kits. Try eBay for those.
Once the shop has the specs they should be able to do it. If they can't, find another shop because it doesn't take a genius to figure out the kits.
Old Oct 26, 2009 | 01:24 AM
Fitcious's Avatar
well here's what i wanted to know:
i dont plan on buying any more kits or what not for the wheels...but my question is, if i do not buy anything and bring the car to the shop as it is, will they be able to align it correctly? thats all i want really..i want my car to drive straight. thanks!
Old Oct 26, 2009 | 09:13 AM
mike2100's Avatar
They'll be able to align the front toe, which makes the front wheels point straight.
Someone who has more experience with a torsion beam rear than I do will have to tell you whether or not the rear toe will be significantly off.
The toe being off is what causes significant tire wear.
If you take it to the shop try to get a printout of the post-alignment measurements and post up a scan of it for us.
The alignment shims are pretty cheap btw
Old Oct 26, 2009 | 11:59 AM
12vltfrk's Avatar
specs are in the back of the oweners book, check it out!
Old Oct 27, 2009 | 12:13 AM
doctordoom's Avatar
Supervillain
i can't say for sure about the ge8 fit because i don't have one, but for the gd3, the fronts can be aligned to factory specs, while the rear's driver side toe will be out and cannot be adjusted without some aftermarket shims like people above already said. but even if the rear toe is slightly out of spec, there is absolutely no abnormal tire wear for the gd3. that is the truth.
Old Nov 21, 2009 | 05:03 PM
rhyneba's Avatar
Alignment specs from Honda
Wheel alignment
Camber
Front
0 ° 00 ’ ±1 °
Rear
-1 ° 00 ’ ±1 °
Caster
Front
3 ° 20 ’ ±1 °
Total toe-in
Front
0±3 mm (0±0.12 in)
Rear
2.5±2.5 mm (0.10±0.10 in)
Front wheel turning angle
Inward
38 ° 04 ’ ±2 °
Outward (reference)
32 ° 00 ’ ±1 °
As of 11.21.09
Old Nov 22, 2009 | 03:28 PM
Nick_'s Avatar
just lowered my car with eibach prokit recently and going to get it aligned pretty soon. so is SPC REAR CAMBER KIT & TOE KIT 07-08 HONDA FIT what we are looking for here? does it fit GE8s?
Old Nov 22, 2009 | 07:47 PM
rhyneba's Avatar
The Honda online parts catalogue show the same front bolt part numbers from 07-10, the rear hub bolts and hub are the same part numbers but the brake backing plates are different part numbers and there does not appear to be a part number for the spindle that is separate from the torsion beam on the 09-10. This can mean either that the spindle (which you need to shim behind on a GD to align) is either welded to/part of the torsion bar (possible) or you can't buy it separately yet on the GE (also possible).
Anybody had a GE down to the spindle? If so, is it removable?
knm345
Apr 12, 2013 01:45 AM
theorbo
May 19, 2010 02:07 PM
CrystalFiveMT
Feb 5, 2009 07:59 AM
roja
Jan 27, 2009 07:10 PM
bdk323
Apr 17, 2008 10:57 PM
