Sponsored by:
Sponsored by:
Using a USB drive with the USB interface, do iTunes songs work?
Old 06-24-2010, 01:12 PM
dontaskbrad's Avatar
I've read a little bit about people using the USB in their cars to plug in a USB flash drive rather than their iPod or iPhone. I assume you just load your mp3s on it and it will find them as it does with your iPod. But I am wondering how it works with music purchased from iTunes. Usually you have to "activate" iTunes on computers and sharing music doesn't usually work since they are "locked".
Anyone know anything about this?
Old 06-24-2010, 01:24 PM
Codger01's Avatar
I load my iTunes library into my USB drive & it plays without any problems. I load it by going into My Music/iTunes & load it from there.
Hope that helps.
Old 06-24-2010, 01:41 PM
That does help. Thanks! I didn't want to go out and purchase a designated USB drive without knowing since 90% of my music has been purchased from iTunes. I have a mac, not a PC, but I assume its the same principle to load them on.
One more question... have anyone been able to do playlists or shuffle all songs with this?
Old 06-24-2010, 01:55 PM
Codger01's Avatar
The USB drive will not support playlists. If your music is DMR protected, the Fit's stereo will not "see"it, & will not play the file. If, after loading your files into the USB you want to add a new file, it will go in as the last file. You can use the "random" setting on the stereo to shuffle your tracks.
Old 06-24-2010, 09:08 PM
specboy's Avatar
Purchased Music that has not been purchased in MP3 Format will not work. the Fit Supports MP3 and WMA ONLY! It does not support the iTunes format so if you have music that has been purchased from iTunes and not in MP3 format, it will not work from a flash drive. You MUST have an iPod to play these types of files.
~SB
Old 06-24-2010, 10:52 PM
sooznd's Avatar
it also supports mp4
Old 06-24-2010, 10:57 PM
Codger01's Avatar
I've never had an issue, but I run iTunes on a pc, not a mac. I just copy my iTunes library from the "my music" folder into the USB & it plays just fine.
Old 06-25-2010, 10:48 AM
Vash's Avatar
when i put itune files into a FLASH drive it does not work when iam using the flash usb drive in the car, BUT if i used an Ipod with the car via USB, it will work.
Old 06-25-2010, 11:04 AM
Codger01's Avatar
Vash- is your flash drive formatted properly? The Fit works with FAT32 & your drive has to be formatted that way.
Old 06-25-2010, 11:29 AM
Vash's Avatar
i guess so... because it can play regular MP3s, but it cannot play itune's digitaly bought stuff. but it doesn't really matter because i use my ipod anyways in my car now.
rr1024
04-02-2014 12:41 PM
nuoccam
09-09-2011 06:23 PM
splat matt
02-16-2011 05:20 PM
reako
07-25-2009 11:38 PM
vclem
09-06-2008 10:26 PM
Quick Reply: Using a USB drive with the USB interface, do iTunes songs work?
