makin stuff
And.... what does it do? o.O?
Based on the name, "tq dampener," I assume it's to prevent the engine from trying to twist its way out of the engine bay when in (low?) gear and you are pressing the gas? I've seen engines rock around in the bay when the gas is pressed (even in parked or neutral), so I kinda see what its for.
I guess my real question is... any noticeable "improvement"?
Nice piece of add-on. Maybe a cap on top of the open pipe? With an H of course.
My only concern is that by mounting it on the crank pulley side you have now created a pivot point. a second twin damper would be about perfect and keep things from twisting and transmitting yet more torque to the wheels, helping WOT shifts, and keeping wheel hop to a minimum.
Motor mounts would go a long way here as well.
But again, well done OP.
The only way I could think of improving upon this would be to mount one closer to the middle as far as the engine block/trans is considered.
i thought about it but this is a natural pivot point making the engine's head strong enough with out breaking/cracking and to mount a dampener on the other side is no structure to mount it to with out re-enforcement to the tranny, i fear the metal might crack but u are right how ever my motor doent move at all and i mounted the shock level so it resisted more instead of pivot. some thought went into it however i recently made a rear under brace tying the 2 spring buckets together will post pics tomorrow
and i did cover the hole wit a spiky thing i found idk looks kool
Hell you could make them for yourself first and then gauge interest! Take a picture of your spikey cap thing!
I'd love to see that brace!
