Front vanity plate holder
The license plate holder? The dealer installed mine and had their advertising in there (GA doesn't require them). When I took it off, there were two bolts that went up into the underside of the upper "lip" in the lower grill opening. There were no exposed holes through the front of the bumper cover (just hidden under the lip).
if it's not on there, DON'T INSTALL IT!!!
seriously, it is the grossest looking thing ever. Do a quick search on the boards for all your other options...you'll be happy that went with the alternate mounting option.
just my 2 cents.
just my 2 cents.
If you have the plastic bit and the mounting bolts, it should be pretty easy to figure out. Look under the front bumper for two holes that match the two on the plate holder; screw in till tight. But unless you're moving somewhere where its required, I wouldn't. That thing is ugly.
