quadruple switch console
Old Feb 13, 2013 | 12:26 AM
gold-civic's Avatar
Does any fit have this console were i can install 4 switches?
or is there any tuner who offer this for a LHD?
Old Feb 13, 2013 | 09:03 AM
jnesselroad's Avatar
I believe that's for a civic si. I don't think it will fit our car, but I would love to be wrong.
Old Feb 13, 2013 | 12:26 PM
gold-civic's Avatar
this pic is from a rhd console for a rhd fit
Old Feb 13, 2013 | 12:45 PM
Oh man, now I gotta get this! Can you post a link to where you found this? I'll search for it too tonight. I'll find out what it takes to make this work.
Old Feb 13, 2013 | 12:59 PM
gold-civic's Avatar
no problem
Honda Jazz GE Start Button Switch - Zerotohundred.com
i need somethink like this, my 3 ports are in use and i would like to install a set of foglights.
this foglights have a switch which have to be install there.
Old Feb 13, 2013 | 01:29 PM
FitStir's Avatar
I saw that on a pic you posted that you have all 3 OEM slots filled... what's are the spots/switches for? Headlight adjustment, VSA, & what else?
I had no idea that was for a GE8 either.... I'm skeptical, since the JDM GE8's have smartkey, I thought the start button was different.
Interested if this is available for LHD, I don't need or want it... just curious.
Incase you can't find an OEM panel, you could just cut a rectangular hole under the 3 OEM switches you have or somewhere else on that panel for the fog switch. Iirc, it should be a relatively simple mod to make the extra switch fit. That should work. Or using an aftermarket switch, like those round toggle type switches.
If not you could get the USDM headlight stalk (which has the fog light controls on the stalk), and try and re-wire or re-route the fog controls to the stalk... just throwing out possible solutions.
Old Feb 13, 2013 | 01:36 PM
gold-civic's Avatar
yes VSA, headlight adjustment and the button for the start/stop function
i do not like the aftermarket switches, love more the oem solution.
Old Feb 13, 2013 | 02:14 PM
FitStir's Avatar
Thumbs up
Originally Posted by gold-civic
.... and the button for the start/stop function
What does it start/stop?
I agree with you on OEM... That's why I mentioned the USDM OEM stalk.
Hey since you're over in Europe, any chance you can post a pic of your "refresh-mode", I hear you guys still have it on the GE8's where as they took it out on the USDM models (made the seat backs larger so it doesn't work).... when you get a chance.. ty.
Old Feb 13, 2013 | 02:30 PM
gold-civic's Avatar
a sample, when you stand before the traffic lights and you put your gear at neutral the engine stops.
if you use now the clutch pedal the engine starts again.
with the switch i can switch this method of.
what do you mean with refresh-mode?
Old Feb 13, 2013 | 02:58 PM
FitStir's Avatar
Thumbs up
Damn... you have a hybrid? or straight petrol? I've only heard of that auto-stop feature on hybrids like the CR-Z. Nice...
Refresh (bottom pic)
Where the front seats fold flat/flush with the rear... kinda like a bed.
Old Feb 13, 2013 | 03:32 PM
gold-civic's Avatar
I have no hybrid, it is a petrol yes.
This feature is new and only the 1.2 have this.
Do not know if my jazzy has this feature, i will try it.
Old Feb 15, 2013 | 09:16 AM
That switch replaces a whole panel on the rhd. At least on ours here in the us, our switch panel is part of a larger l-shaped piece that goes down and around the steering wheel. No luck on getting that piece for the us models at least.
Old Feb 18, 2013 | 01:52 PM
gold-civic's Avatar
our panel look like this
sorry, also no refresh-mode on our GGs, also the back seat is larger.
Old Feb 18, 2013 | 09:54 PM
ampete04's Avatar
I don't know if this is what you have in mind, but it gives you 4 switches.
Old Feb 18, 2013 | 10:16 PM
ampete04's Avatar
Might be able to import from here
Old Feb 21, 2013 | 12:22 PM
gold-civic's Avatar
Nice option, gut my Jazz does not have a eco option
SilverEX15
Aug 8, 2014 08:27 AM
damatick
May 26, 2011 10:56 PM
OhNineFIT
Sep 3, 2009 12:19 AM
FELIXY69
Sep 2, 2008 04:15 AM
hazzard
Nov 30, 2006 08:16 PM
