Header & B-Pipe install question
Old May 8, 2008 | 10:24 AM
Mynute 1's Avatar
Senior Member
I received my T1R header and B-pie the other day and had a question for those who have made a header/b-pipe install. First, do I need to replace the original gasket at the header local? Is there even one there. Second, I saw that the b- pipe came with two new gaskets. Do they go in the middle & the cat end, or do the go in the middle & the muffler end. Any knowledge from anyone would be appreciated. Thanks!
Old May 8, 2008 | 12:33 PM
doctordoom's Avatar
Supervillain
to answer the question about the b-pipe gaskets, they go on the "cat end" and the "middle end." the connection to the muffler should re-use the oem donut gasket. pry it out carefully from the original b-pipe so that you don't damage it and re-use it.
Old May 9, 2008 | 12:50 AM
Mynute 1's Avatar
Senior Member
Thanks
Old May 9, 2008 | 03:27 AM
doctordoom's Avatar
Supervillain
no problem! sorry i don't know anything about the header install though
Old May 9, 2008 | 11:03 PM
Arisenfury's Avatar
There should be a gasket already between the OEM headers and the exhaust manifold, I reused that one since the Weapon*R ones did not come with a new one. If the T1R doesn't either than just reuse the OEM one.
Vash
Jul 25, 2016 07:44 PM
Orcshine101
Dec 28, 2014 01:24 AM
SlowFit13
Dec 11, 2014 07:04 AM
im the fit
Apr 6, 2009 10:26 AM
DrKelso
Nov 17, 2008 06:19 PM
