T1R response header
Old Aug 12, 2014 | 12:50 AM
SlowFit13's Avatar
T1R response header
I have been reading all the Weapon R header (deletes both cats) threads since I am interested in making a little more low and mid range power. There is only one problem, I kept reading The exhaust is raspy no matter what kind of set up you have, including stock. Why not run the T1R response header and bolt it up to the stock second cat, B pipe, axle back? From what i have read it is the first cat that is restrictive and the pipe design is less then desirable. Would the T1R header with out the second cat delete do much for power, and keep the rasp down since the second cat would still act as a resonator?
Here is the picture that got me thinking.. This is the weapon R though.
The Stock exhaust makes a 90 degree bend right into the cat, not smooth at all
Old Dec 9, 2014 | 06:17 PM
BMW ALPINA's Avatar
I think I will be able to know the answer for this very soon
My T1R Header suppose to arrive today, and I plan to keep the second cat...
(probably do a high flow cat conversion)...
after that I need to do ceramic coating (the place told me it might took up to 2 weeks to do ceramic coating???),...
so hopefully I am able to install by the end of this month or early next year
Old Dec 11, 2014 | 07:04 AM
Myxalplyx's Avatar
Cel
I'm interested in knowing how you guys eliminate the CEL.
Also, wouldn't adding an a resonator or two help out with bringing down some of the noise?
icollins247
Mar 11, 2016 10:55 PM
Orcshine101
Dec 28, 2014 01:24 AM
cfran55
Aug 7, 2014 08:46 PM
preludetofit
Dec 29, 2012 01:02 PM
jjboyes06
Jan 19, 2011 10:19 AM
