squeking coming from rear?
Old May 19, 2008 | 10:51 AM
mikow's Avatar
ok so i just installed the skunk 2 springs and progress rear sway.
there is a loud squeking noise coming from the rear.
i think it's from the rear sway?
is this normal?
and the ride is very bumpy.
my mom was like hella mad cause she was like "it's a new car, and it doesn't even feel like a new car anymore!"
damn dude, what should i do?
Old May 19, 2008 | 11:04 AM
GD3-Fit's Avatar
I <3 SPOON
is this normal?
I think it's due to the fact that skunk 2 springs are stiffer than the stock springs so it will be more bumpy.
and the rear sway helps keep the rear end more stiff also
as far as the squeaking, since you just put your springs on mine squeaked for a week or two and it went away.
maybe someone else can chime in.
-Ricky
Old May 19, 2008 | 11:34 AM
mikow's Avatar
-Ricky
oh ok, well i'll see if it squeeks still in a week or two and get back on this matter
thanks
-Mike
Old May 19, 2008 | 01:09 PM
jeffquach's Avatar
are you using the bolts supplied by progress? the bolts are probably making your springs rub against the spring carrier wall. you will need smaller bolts.
Upgraded Hardware Kit for Progress Rear Sway Bar
EDIT : i think kelsodeez grinded his progress bolts...that's another solution as well.
Old May 19, 2008 | 01:25 PM
SpoonSportFit's Avatar
yea if it doesn't go away you might want to check out your springs i heard some cases that people install the spring upside down and it squeaks until they reinstall it
Old May 19, 2008 | 01:36 PM
mikow's Avatar
well at first my boy installed the passenger side rear upside down.. but i fixed that.. and it's still squeaking hella loud.
so you think it's the springs?
well let me give it a week and let me get back to you guys on this
Old May 19, 2008 | 02:12 PM
mikow's Avatar
ok guys, just went out for my break and checked out my suspension again.
it looks like the right passenger side rear that we re-installed yesterday is good. (that's why the squeaking was less when we did this)
but the other side rear drivers side, i can see the spring rubbing against the wall and scratching the spring. and i think that's what's causing the squeeking noise..
i guess i will try to fix this with my dad when i get home from work.
it's gonna be hard to take off the bolt though because my boy that installed the springs torqued it down too much.
yesterday when we were re-installing the passenger side rear we had a hard time taking the bolt off.
geez.. problems problems problems problems!
i'll let you know if the squeeking stops guys
thanks,
Mike
Old May 19, 2008 | 09:06 PM
solbrothers's Avatar
ive tried grinded bolts and even replaced teh bolts with some other bolts that were WAY thinner, and still have squeeking issues.
btw, teh swaybar won't make your rider bouncy at all. it doesn't affect the motion of the suspension front to back, only side to side
Old May 20, 2008 | 03:00 AM
doctordoom's Avatar
Supervillain
a bump that would normally only be felt on the left rear wheel will be felt more strongly on the right rear wheel if you have the rear sway bar. i would classify that as something that affects the ride.
hayden
18
Apr 30, 2012 12:12 PM
harispirzada
Apr 28, 2009 09:53 AM
DENRACING
Apr 13, 2008 09:03 PM
Amageus
Feb 20, 2008 09:04 AM
Hondady
Apr 16, 2007 07:45 PM
