The Lethbridge AutoX!
Old May 21, 2008 | 10:17 PM
Sugarphreak's Avatar
Push My Button
Ok, for those of you who don't want to wait until September to test out all the new parts and put your sharp Fit driving skills to the test.... let's get a date setup for a roadtrip down to Lethbridge for some serious fun!
Available Dates:
July 6 - Event 4 (Exhibition Park, Lethbridge)
July 20 - Event 5 (Exhibition Park, Lethbridge)
August 4 - Event 6 (Exhibition Park, Lethbridge)
August 10 - Event 7 (Exhibition Park, Lethbridge)
Stuff you NEED to know:
1) You need a SNELL 2000 or greater helmet, DOT is not acceptable
2) Pre-Registering will save you 10$ and guarantees you a spot (not open for sign up yet)
https://www.karelo.com/enter_res.php?&BID=334#Ev6095
2b) Bring proof that your pre-registered!
3) Read the supplementary rules
http://sascsolo.ca/forum/download/fi...7d322771821a84
4) Leaving early (without consulting early with organizers early on) or not doing the required volunteer Marshalling work will give you a big fat DNF for your times.
Stuff you probably should know:
1) Run about an extra 10psi in the tires
2) Bring painters tape or white shoe polish... or both
3) Bring Suntan lotion, Wear appropriate clothing, umbrellas are your friend!
If you want to go; post up all of the dates that work for you below! Put them in order starting from the most preferred to least preferred.
(Also List your engine, wheels & suspension modifications below so we can establish your vehicle class for the pre-registration.)
Old May 21, 2008 | 10:42 PM
Push My Button
I think somebody;
-Wants to try out a new supercharger
-Wants to setup a new sponsor tent and try some new tires
-Wants to embarrass the rest of us with his stock fit
-Wants to try out some killer RPF1's and fat tires
-Wants to show off that vented carbon hood and prove that old people can still drive
Old May 22, 2008 | 08:32 AM
Mr_ET's Avatar
How does July 20th work for all you other guys?
My all seasons and stock suspension will own you all
Old May 22, 2008 | 09:34 AM
Illusive's Avatar
July 20th works for me!
Old May 22, 2008 | 11:47 AM
JDMish's Avatar
Company golf tourney that weekend, i'm out
Old May 22, 2008 | 12:24 PM
Push My Button
what other dates work for you?
Old May 22, 2008 | 04:04 PM
JDMish's Avatar
july 6th, aug 4th
Old May 22, 2008 | 04:40 PM
Push My Button
6th is probably better for me, however I could swing the 4th if somebody has a schedule conflict
Old May 22, 2008 | 06:16 PM
Mr_ET's Avatar
August 4th would work for me as well.
Old May 26, 2008 | 03:15 PM
Push My Button
A few more pics surfaced today from that event, the car is looking pretty solid on those corners.
Notice anything hiding in the bushes in the first picture
Also, check out Asimo in the second pic, he is going for a spin!
Old Aug 4, 2008 | 01:24 AM
Push My Button
Well I am off to Lethbridge tomorrow morning. Wish me luck!
I am feel'n good, car seems to be running great and putting down some decent power. This is going to be a tough one as the lethbridge track is a lot more spread out, the cars with the real power are going to benefit with the longer straight stretches... my poor Fit will be struggling a bit to keep up.
Old Aug 4, 2008 | 11:44 AM
Mr_ET's Avatar
sounds like you could use a header, test pipe and a full adjustable suspension my friend
Old Aug 4, 2008 | 10:18 PM
Push My Button
I have a header.... but yeah a test pipe and a real suspension kit would go a long way to helping me.
As I suspected my car is pretty weak on the straights and this course had some long ones. I was also having some issues dialing in my tire pressure, my first run was a disaster because I had WAY too much pressure once the tires heated up. I bled off about 15lbs per tire through my next 3 runs and got some better traction that way. 41psi is the sweet spot for my tires, keeping it there with hot track temps was a challenge.
Hmmmm, I think my tires look pretty roasted! I need to take a tread wear indicator to it
Anyway, I placed 18th overall officially out of 26 cars. Was pretty fun!
Old Aug 4, 2008 | 11:31 PM
Mr_ET's Avatar
then all I see left for bolt ons is a cam, cam gear and that test pipe. Some tuning with the eManage will help also after.
To be honest when you track the car I would really really recommend either a 16 or 15 inch wheel/tire package.
If you get some traklites or something like that with some Falken RT615`s or some toyo ra1`s you will do much better.
Your 17`s are heavy and hurting you all around the track.
Post some pics of the event man
Old Aug 5, 2008 | 12:49 AM
Push My Button
I only snapped a couple of shots of the cars in it. No action ones this time
Yeah the 17's probably hurt me, but they look so damn cool
I am pretty much done now, I have a few loose ends to tie up like the pulley and short shifter... and one day side skirts. But I am looking to the future, hopefully I will have a new toy next year That new toy needs some compound R's!
I took the silencer out for this event, my car is freaking loud and backfires like crazy!! lol, I had people doing double takes because it sounds like a V8 or something now.
Old Aug 5, 2008 | 11:31 AM
JDMish's Avatar
Sounds like a good time. We definitely need to get you in for some work before you get your new wheels
Cant wait to see some pics!
Old Aug 5, 2008 | 11:56 AM
Push My Button
I was thinking about picking up a set of these for my stock rims, I think it will drop me into a lower class as well; will have to consult the rules.
Hankook Ventus R-S2 (225/45/R15)
EDIT: Damn, the only thing keeping me out of STX is my manifold
Mind you the PAX on FSP is only 0.833 and STX is 0.820 so it wouldn't help as much as it would put me at a disadvantage.
Old Aug 5, 2008 | 12:34 PM
Push My Button
Hmmmm, Falken makes the ZIEX ZE912 in a 225/50/R15
Do you think that would mount up to a stock rim without rubbing?
Old Aug 5, 2008 | 12:46 PM
JDMish's Avatar
the ze-912's are not a autocross worthy tire, they are an all-season performance tire. I'd try and stick with the rt-615's if you could but the largest is a 205/50
if you can wait till sept we can all try the set that i have and see how they handle.
Old Aug 5, 2008 | 12:56 PM
Mr_ET's Avatar
That sounds like a plan!
now all we need is a George Forman Grill and some burgers to make this day epic!
