Defrost = A/C on... how do I disable it?
Old May 22, 2008 | 01:12 PM
jimmy996's Avatar
Heya,
Ive been getting really unimpressive gas mileage since i bought the car, and just today a honda service guy tells me that if you have the air vent set to defrost the A/C is automatically turned on.
so thats probably a lot of the problem, does anyone know where the wire is so I can clip it, or where the switch is that will allow me to disable this automatic "safety" setting?
Id like to start seeing the mileage that everyone on this forum is so pleased with.
Old May 22, 2008 | 01:17 PM
hiroko12's Avatar
Define unimpressive? Also, the A/C will not affect your gas mileage by much anyways. All cars use the A/C with defrost, not just the Fit.
Old May 22, 2008 | 01:23 PM
jimmy996's Avatar
Unimpressive is an average of about 9.5 litres to 100 km mostly highway.
the sticker said 5.8 highway and 7.3 city.
6200km on it sofar. so im really not seeing the fuel savings that are advertised.
Old May 22, 2008 | 01:29 PM
07fitsport's Avatar
you can disable this feature by carefully removing the cover under the ac ccontrol knob...(small panel) then in the middle you will see a very small clip that plugs in (think it is white) and just push in small clip and pull..
this will diable the feature and also tho it will allow the lights to the knobs to be diabled also that allow them to be turned on when your headlights on.
Old May 22, 2008 | 01:35 PM
fit4jenn's Avatar
the a/c is on because it helps your windows defrost faster, while you have it set to a hot temp.
Old May 22, 2008 | 01:36 PM
solbrothers's Avatar
how about you change your driving habits. if you are interested in getting better mileage, get a scangauge.
Old May 22, 2008 | 01:41 PM
xorbe's Avatar
fitfreak linkage:
https://www.fitfreak.net/forums/fit-...html#post89166
It's a physical switch, no magic will turn it off. Unplug the switch cable.
Old May 22, 2008 | 01:47 PM
jimmy996's Avatar
sweet, thanks!
Old May 22, 2008 | 01:48 PM
Originally Posted by jimmy996
sweet, thanks!
replied to your PM
Old May 22, 2008 | 08:14 PM
mahout's Avatar
9.5 L per 100 km is 24.7 mpg. If you drive aggressively, keeping the rpm above 4000 rpm to extract max performance you should expect 9.5L per 100 km.
And a/c is used on 'defrost' for most cars because it assists defrosting the windshield. For those of us who remember what it was like before, it was actually possible to add humid moisture to the windshield, making vision even more difficult.
And as others said, a/c doesn't affect your fuel consumption nearly as much as your driving habits.
When I go to the track my track mileage runs about 20 mpg but thats wide open extraction of performance.
I don't know what country you are in but the sticker saying 5.8 to 7.3 L/100 km is 32 to to 40 mpg which is better than the US stickers (28 to 33 mpg).
Old May 22, 2008 | 09:44 PM
ricohman's Avatar
If I dissable this feature am I to undertsand the lights will no longer work in the controls for the heater knobs?
Old May 23, 2008 | 01:40 AM
xorbe's Avatar
I don't know, but you can always plug it back in! For some reason I want to guess that it doesn't affect the light. I did not read that anywhere yet. People would be quick to complain about that.
Old May 23, 2008 | 02:01 AM
storm88000's Avatar
Frequent FitFreak Poster
Not true. Most newer cars do, but before circa 1998 they don't.
Old May 23, 2008 | 12:34 PM
cab0053's Avatar
If your miles/km are low, that may be it as well.
Old May 27, 2008 | 04:10 PM
grimm79's Avatar
Huh that is strange. When I had the defrost on in mine the A/C never came on.
Old May 27, 2008 | 05:00 PM
ricohman's Avatar
The light does not come on but the compressor does engage above a certain temperature or pressure.
Anyone know what that temperature is?
ftlmatt
Jan 17, 2022 02:12 PM
Ladylockness
Aug 30, 2012 01:24 PM
warner
Sep 13, 2009 10:54 AM
Firebat666
Jun 11, 2008 11:55 PM
facade
Apr 18, 2008 02:48 AM
