18" anyone????
Old May 25, 2008 | 01:16 AM
Previc93's Avatar
18" anyone????
i was wondering if anyone had any 18" wheels on a fit? i am wheel shopping and i wanted to know if they could fit.
Old May 25, 2008 | 03:24 AM
Jake's Avatar
Of course they can fit. running 18s with like a 35 series tire will be probably maybe a little bit bigger than the overall diameter of the stock rim and tire setup
Old May 26, 2008 | 02:46 PM
MarkyMark's Avatar
Toyo T1R's come in a 205/35R18 that is 23.7" in diameter, which is pretty close to the stock 23.4" The usual 215/35's are 23.9".
Old May 27, 2008 | 02:48 AM
MINI-Fit's Avatar
Sure, 18" wheels will fit the Base Fit or Sport models.
Tirerack lists at least 27 different wheels that are 18" for the Fit.
18x7 to 18x8"
many 18x7.5" with +37 to +45mm offset
215/35-18 tires
Compare Tire Search Results
23.9" tire diameter should fit OK for stock suspension, be careful when lowering since some wheel offsets are +4 or +5 offset. Safer with +45mm offset if lowering.
Old May 27, 2008 | 04:01 PM
Spencer@tirerack's Avatar
Former Vendor
18" fit fine, but they will drop your gas mileage and cost more. they look cool tho
Old May 27, 2008 | 04:26 PM
SD_MR_FIT's Avatar
the tijn fit has 18x8 on there car i think.
sooo sexy!
but honestly i have 17's and it sooo hard to keep them from curbing!
i mean just roads in general will murder those wheels. and thats rocking a 40 series. just think about like 35 or 30 series. super hard!
i wouldnt rock 18's...you better be tire tucking to make that look nice. its hard already to make the 17's work
Old May 27, 2008 | 05:34 PM
Fitcapo's Avatar
i wouldn't do 18s I have 17s and they are already plenty big with a small ass tire.
Old May 27, 2008 | 08:12 PM
mimpi's Avatar
dont go any lower than 40+ offset on the 18", i tell ya, scrubbage on 18" is not as fun as on 15s" or 16s".
Old May 28, 2008 | 07:17 PM
dcmcelreath's Avatar
I only have this half car picture, but these are Racing Hart GT5's in an 18"
Car is lowered on df210s, and it was tuckin like half of the tire, lol.
I am pretty sure the tires were 215/35s so that was part of the rubbage also.
Hope this helps!
Dustin
Old May 30, 2008 | 06:21 PM
Previc93's Avatar
Thanks everyone and thanx for the pic. it looks sick with the tuckage but i dont want it to rub. my bro had 18s on his civic and i had to align the camber to be negative so the tires wouldnt rub the fender. it looked sick and handled awesome. but tires get expensive. so i think ill just get some 17s. i apreciate all your guys help.
Old May 31, 2008 | 02:00 PM
Devolutionized's Avatar
I have a set of 18x7.5 that i took off my 01 civic before i traded it in. I want to throw those on the fit but want different tires. The tires on there now are 215/35 18, and there is a slight gap between the tire and the lip of the wheel. I would like the tires come out at least to the edge of the wheel if not over a little to keep curbage down.
the 225/35r18 would be an increase of .58" to the overall diameter of the tire. would this create problems with suspension, brakes of bearings?
Thanks,
Phil
Old May 31, 2008 | 03:05 PM
osborne's Avatar
I have to agree with SD_MR_FIT and Fitcapo. 18s are just plain to big for this car. IMO 17s are the way to go and with a 40 sized tire the diameter increases by 0.012".
Old Jun 1, 2008 | 07:38 PM
whtsjdm's Avatar
18" rims or bigger make fits look like a damn DONK imo. It's all in what you like, but I'll stick w/ my 15/16" rims and have my fit dumped =)
Old Jun 1, 2008 | 11:16 PM
SD_MR_FIT's Avatar
so my car is donk?
im pretty sure last time i check i was lower then most people with 15's AND 16's heh.
i thought donk is big wheels with a big lift...
heh, its okay...everyone has their own opinions.
Old Jun 2, 2008 | 11:33 AM
Previc93's Avatar
I want to put a big brake kit on my car and most of the kits say at least 17's. i know a fit is so light and really doesnt need it. but i think it looks pimp.
Old Jun 2, 2008 | 08:21 PM
SD_MR_FIT's Avatar
meh thats true. the fast brake kit needs 17's.
but you can do the civic rotor swap. that way you can keep 16's
Old Jun 6, 2008 | 06:26 PM
osborne's Avatar
Originally Posted by whtsjdm
17" rims or bigger make fits look like a damn DONK imo. It's all in what you like, but I'll stick w/ my 15/16" rims and have my fit dumped =)
I don't think my 17s make my car look donk.
Old Jun 7, 2008 | 10:16 PM
Mr.FIsTer's Avatar
dude thats totally donk! you should be in that donk king mag! i like the way your car is "murdered out"...totally gangsta!
Old Jun 8, 2008 | 03:59 PM
whtsjdm's Avatar
I guess I'm too use to seeing fits with 17" rims and up with no drop =/ Clean rides guys
Old Jun 12, 2008 | 07:48 PM
FormulaJDM's Avatar
Here is another Fit on 18's.
