Stock speaker wire colors
Old May 25, 2008 | 11:46 PM
Rod2Rice's Avatar
Anyone have info on the stock speaker wires, as to what color is + and - at the doors for each one? I was just looking at the oem speakers I pulled out, and thinking I may have reversed the wires in either the fronts or rears. Gonna end up pulling the panels to check, but would be nice to have handy the schematic so I know for sure. This is for an 08.
Old May 26, 2008 | 04:20 PM
Injundon's Avatar
RF+ Red w/ Green Stripe
RF-Brown w/ Black Stripe
LF+Blue w/ Green Stripe
LF-Gray w/ Black Stripe
RR+Red w/ Yellow Stripe
RR-Brown w/ White Stripe
RL+Blue w/ Yellow Stripe
RL-Gray w/ White Stripe
That'll cost 1 rep point
Old May 26, 2008 | 04:32 PM
YeeFit's Avatar
This will cost +1 rep points too
KEYSENSE
green/white
ign harn or gcm, 40 pin plug, pin 11
Notes: The GCM (Gauge Control Module) is incorporated in the instrument cluster.
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pin 8.
POWER LOCK
white/green
dr kick or gcm, 40 pin plug, pin 9
POWER UNLOCK
white/blue
dr kick or gcm, 40 pin plug, pin 10
DOORLOCK MOTOR
white/black
5wi
fuse box, green 8 pin plug, pin 2
DOOR UNLOCK MOTOR
yellow/black
5wi
fuse box, green 8 pin plug, pin 5
FACTORY ALARM ARM
white/red
dr kick or scu, 20 pin plug, pin 4
Notes: Meter this wire while turning the key in the driver door key cylinder.
The SCU (Security Control Unit) is under the driver side dash.
FACTORY ALARM DISARM
white
dr kick or scu, 20 pin plug, pin 3
PARKLIGHTS POSITIVE
red/black
fuse box, 14 pin plug, pin 5
PARKLIGHTS NEGATIVE
blue
switch or gcm, 40 pin plug, pin 19
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 16 pin plug, pin 5.
HEADLIGHT
brown/yellow
switch or gcm, 40 pin plug, pin 36
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 16 pin plug, pin 4.
HAZARD
same as turn signal wires
TURN LEFT
green/red
switch or gcm, 20 pin plug, pin 6
TURN RIGHT
green/yellow
switch or gcm, 20 pin plug, pin 5
REVERSE
green/black
fuse box, 14 pin plug, pin 9
BRAKE
white/black
sw or fuse box, 14 pin plug, pin 4
PARKBRAKE
green/orange
DOOR PIN
green (d), purple (p)
kick or gcm, 20 pin plg, pins 14, 13
Notes: Use both wires and diode isolate each.
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pins 20 and 9.
HOOD PIN
green/black
pin sw or scu, 20 pin plug, pin 18
Notes: The SCU (Security Control Unit) is under the driver side dash.
TRUNK PIN
green/red
dr kick or gcm, 20 pin plug, pin 16
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pin 7.
DOMELIGHT SUPERVISION
green/red
fuse box or gcm, 20 pin plug, pin 12
TACH
green/orange
ac
fuse box, 6 pin plug, pin 2
Notes: Can also go to any fuel injector and use the wire that is NOT yellow/black.
Can also go to any ignition coil and use the wire that is NOT black/white or black.
VSS
purple/white
radio harness
LEFT FRONT UP/DWN
red/black - red/yellow
A
driver window switch in door
RIGHT FRONT UP/DWN
blue/red - blue/white
A
driver kick, door harness
LEFT REAR UP/DWN
brown/white - brown
A
RIGHT REAR UP/DWN
blue/orange - brown/yellow
A
HORN
orange
switch or gcm, 14 pin plug, pin 8
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 16 pin plug, pin 2.
WIPER
blue/yellow (l), blue (h)
windshield wiper switch
RADIO 12V
white/red
radio harness
RADIO GROUND
black
radio harness
RADIO SWITCH
yellow/red
radio harness
RADIO ILLUMINATION
red/black
radio harness
POWER ANTENNA
radio harness
LEFT FRONT SPEAKER
green/black - lt. green
radio harness
RIGHT FRONT SPEAKER
green/yellow - gray/red
radio harness
LEFT REAR SPEAKER
blue/white - blue/black
radio harness
RIGHT REAR SPEAKER
pink - blue/yellow
radio harness
Old May 26, 2008 | 04:45 PM
Injundon's Avatar
Posting that much info online is DANGEROUS. I've seen it happen. People with no experience working on cars jumping in with a test light or worse.. just taping any wore of those colors (in Hondas they like to repeat themselves in some cars)....
So Just heed my warning. Just because you have the wire colors available. DO NOT attempt to install your own alarm/starter in a fit.
(not to anyone specific)
Old May 26, 2008 | 05:03 PM
YeeFit's Avatar
Agreed. If someone is to do their own work, they do need to follow proper installation techniques and guidelines.
I'll remove the Ignition Harness information.
My Bad.
P.S. NEVER EVER PROBE THE THICK YELLOW WIRES UNDER A DASH OR AROUND THE VEHICLE, UNLESS YOU HAVE A AIRBAG SAFE TEST LIGHT. EVEN IF YOU DO HAVE A AIRBAG SAFE LIGHT, I WOULD NOT RECOMMEND PROBING THESE WIRES UNDER ANY CIRCUMSTANCES!
Old May 26, 2008 | 11:08 PM
Rod2Rice's Avatar
I'll throw some rep to both of you for the effort, but Injundon the colors you list for the speakers are not correct, and YeeFit your were all the same except for one speaker. I found a fsm that I downloaded, and checked the wiring diagram for the speakers and it matched the leads for mine. I cut off the oem terminals and left a bit of wiring on them so if the day comes I get rid of this car, the stock junk can go back in. The leads do work out like this
FR+ = green/yellow
FR- = gray/red
FL+ = green/black
FL- = light green
RR+ = pink
RR- = blue/yellow
RL+ = pink
RL- = blue/yellow
And what this means is I think I wired the fronts backward, and would explain why they don't sound any better than stock. I am going to try and surface mount my Kappa tweeters this weekend if there is enough room, so I will fix the wiring then. I think with one of the many mounting options they come with I may be able to get one to work, not the way I wanted to do it but what can ya do. They certainly aren't the nicest looking tweeters I've seen!
Old May 27, 2008 | 01:12 AM
Injundon's Avatar
wiring speakers backwards will in no way affect sound quality. It's only if 2 or more speakers are wired incorrectly, it makes them work against each other in a way. If all 4 were wired wrong it would sound no different than if they were wired "correctly"
The +/- deal is much more a "reference" to keep all speakers on the page figuratively speaking.
Old May 27, 2008 | 08:01 AM
Rod2Rice's Avatar
Yeah I think I wired the rears correctly, and the front woofers backwards, and the stock tweeters are using the original wiring. I also got an email back from Infinity saying I could use the smaller 10.7t tweeters just fine in place of the 10.9 ones, so thats some good news. Crutchfield had advised me not to, but in this case I think I will go with the makers advice.
Old Jul 1, 2008 | 08:26 PM
Lear 45's Avatar
YeeFit, you forgot the wire colors for the airbags!
Old Sep 21, 2008 | 12:32 PM
ShannonHonda.aka.Fit's Avatar
Cool I need to install sub and amp to my factory head unit
I want to install a sub and amp to my factory head unit. I have my amp kit, line converter and i am trying to avoid any possible splicing. I have not sat on the car and stereo long enough to think of how to do it, nor have i taken anything apart yet. I have done all the mechanicals to my fit... short shift, intake, exhaust etc. Now i am moving on to the stereo. I have done honda installs before but it was on a 85 honda prelude. The dash was simple to pull apart and get to the deck. In addition it was an aftermarket deck i was putting in. Now can i splice the rear speakers through the wires running out of the head unit or is it more complex than that with theses fits?
Has anyone attempted this on the fit themselves and how was it accomplished?
Old Dec 12, 2008 | 08:40 PM
spinnb7's Avatar
so i just pulled the factory head unit in my 09 sport, and the color wires that i have do not match any of these.
i have black, pink/silver, gray, brown, blue, light blue, light green, light grey among others. do the 09's have a different color from the 08?
Old Jul 8, 2010 | 11:16 PM
phatboycrxhf's Avatar
FR+ = green/yellow
FR- = gray/red
FL+ = green/black
FL- = light green
RR+ = pink
RR- = blue/yellow
RL+ = pink
RL- = blue/yellow
thats all correct except for the rear speakers..the right rear is + pink and the - is blue yellow,but what is the right left speaker ?
Old Oct 2, 2016 | 03:42 AM
ndub's Avatar
i have an 07 fit could anyone tell me where the ground is for the stereo and actually also a good place to ground an amp if you know too i would be very thankful
xenomorph
Feb 14, 2011 04:10 AM
Perrenoud Fit
Oct 2, 2010 08:59 PM
tight_fit
Mar 23, 2007 08:42 PM
fm2n
Jun 28, 2006 01:58 PM
Pat T.
Jul 9, 2005 10:07 AM
