Time for new tires. Proxes T1R opinions?
Old May 29, 2008 | 08:25 AM
sortanewinatl's Avatar
I need to order new tires tomorrow. I have Falken Ziex 512's now. They've been good tires but I want something a little more agressive this time. I'm interested in Proxes T1R's because they are light... 4 lb lighter than most anything else. I've found several reviews complaining about soft side walls on them, but they are mostly reviews comparing them to Azenis 615's and the like; also on much heavier more powerfull cars. Anyone have experience with these?
They are $80 /per tire at Edge Racing. Azenis 615's are $72
Old May 29, 2008 | 08:39 AM
GD3-Fit's Avatar
I <3 SPOON
If you don't mind getting new tires sooner down the road then i would go with proxes t1r. they are a softer compound tire and have excellent grip. treadwear is on the low side. great price for the t1r's though.
where as the azenis 615's may last longer
i have never bought falken tires so i can't tell you about them
i like to stick with yokohama and bridgestones and bf goodrich's
but that's just me
hope i helped a bit
-Ricky
Old Jun 2, 2008 | 10:56 AM
racecarshots's Avatar
had those on the miata (and the fit for about 500 miles till I decided 35mm offset was too much and rubbing was lame). Liked them a lot. They wore suprisingly slowly for their grip level. I had probably 10k on them and there was a lot left.
Old Jun 3, 2008 | 10:37 AM
Nerdsrock22's Avatar
I've got them and love them! Much grippier than the Parada Spec 2's and General Exclaims I've had before on other cars...
Old Jun 3, 2008 | 12:09 PM
go shop at tirerack and get selection on other real tires.
Old Jun 3, 2008 | 01:41 PM
mahout's Avatar
The Toyo tires are good but like others said they have low wear numbers. I wouldn't count on getting even 10k miles. The lighter weight is from thinner sidewalls and carcass for softer ride and the reduced weight helps a bunch on acceleration.
You pay your money for what you get.
You should mention your wheel and current tire sizes.
Old Jun 3, 2008 | 10:52 PM
I have 15'' Konig Heliums w/ 195 55 15 Falken 512's now...
That's what i suspected, regarding the weight/sidewalls.
I just want something a little stiffer with decent grip and decent treadlife... 20-25k. The guys at edge racing said the Falken 912 (replaced the 512) is stiffer and it's cheap... so I think I'll go that route. I traded the VW in for the Fit so I would stop throwing money at it... can't justify high end tires.
Old Jun 3, 2008 | 10:53 PM
thanks... that bit of insight was very helpful...
Surviver of the Fittest
May 16, 2014 01:57 PM
lylee
Apr 24, 2011 11:24 PM
running
Mar 5, 2011 09:46 AM
Guinness
Dec 5, 2009 04:20 PM
shazaam
Apr 16, 2009 12:20 AM
