View Single Post
  #31 (permalink)
Old 06-03-2008, 11:09 PM
rocksnap rocksnap is offline
rocksnap is an unknown quantity at this point
sirius antenna
Holy cowabunga! I was just looking at the above antenna routing that the guy put in thru by removing the side panel and spare tire area! I just routed mine up the center mirror into the headliner, across to the drivers side, then all the way down the left side. Tucks nicely, and quickly, into the headliner, including the rear hatch trim. I do have a very small bit of antenna wire exposed at the hatch but that is only seen when the hatch is opened. Most people would not even notice! I give the guy credit for going thru all that time and trouble but...
I have three wired coming off my Sirius head unit. Power, antenna and line out to my aux input. All those get routed up the center mirror. They are even held in by the rubber (mirror to windshield) support, against the mirror arm. All out of sight.
If you want to spend all that time taking the interior apart that is your call. I will be off starting my third beer while you are still putting your car apart!
