sirius radio anybody?
Old Oct 18, 2008 | 09:29 AM
mardar7's Avatar
Anybody with an 09 Fit have a sirius radio installed? If so, where did you put the radio and where did you mount the antenae?
Old Oct 22, 2008 | 04:11 PM
barams's Avatar
i have a fit sport w navi. i'm looking for a complete solution for using sirius on my nav unit.
nothing is out there right now. been searching the crutchfield site for a solution.
Old Nov 18, 2008 | 09:40 PM
DrHog's Avatar
I also have the '09 Navi, and came to the same conclusion--no way to integrate Sirius with my Navi, short of replacing the whole system with one from the Civic. No way....
I went with the Sportster 5 with vehicle kit. All in all, it's a pretty clean setup. If you're already a Sirius customer, you can get it all for $99 with a 2 year subscription. I had it installed by a pro. He put the antenna right behind the AM/FM antenna. The radio and suction mount go on the front quarter-window, with the power, antenna, and aux line wires neatly tucked in around the back of the window. The radio is clear of the cupholder and vent, but close enough to reach. I use the remote almost exclusively.
One trick with this radio you might want to use: I had the installer wire it so that the radio can receive power even with the ignition off. The combination of this and using the "pause" feature allows me to record shows while I'm out of the car, and then FF through the commercials when they come. You can set the Sportster so that it powers off after an hour of inactivity, which will save your battery in case you forget to turn it off for a long period. I was really bummed about not being able to integrate the satellite radio into the Navi, but this "Tivo" feature more than makes up for it.
Good luck!
Old Nov 18, 2008 | 09:46 PM
neteng101's Avatar
XM here - preferred the XpressRC, pictures here of my install...
2009 Honda Fit - Satellite Radio Install - a set on Flickr
SilverEX15
Aug 2, 2014 06:38 PM
Texture
Nov 6, 2011 05:43 PM
Norman99
Jun 22, 2011 04:31 PM
orion42
Jan 23, 2009 08:54 PM
SilverBullet
Dec 30, 2007 06:39 PM
