TIR header installed-quiter exhaust!?
Old Jul 4, 2008 | 01:40 AM
hondajazz2005's Avatar
y does some ppl said installing a header will lost low end power?? or you need to tune it??
Old Jul 5, 2008 | 12:27 AM
Scratch&Dent's Avatar
Actually, depending on the header, you can gain low-end torque. I bought the T1R Response header, and it improves the low-end. Same with the Weapon-R header.
The T1R Power header, on the other hand, improves mostly the high-end torque, and so does the Megan header.
Old Jul 5, 2008 | 12:41 PM
QuickGD3's Avatar
So there is a T1R Response header and a T1R Power Header?
Old Jul 5, 2008 | 01:00 PM
Yes, but for the Fit T1R only makes the Response header
Old Jul 5, 2008 | 01:29 PM
QuickGD3's Avatar
Got It
Old Jul 31, 2008 | 11:17 PM
Skierdood's Avatar
Hey guys new here I drive an 08 VBP Fit Base 5MT. I am looking to to some minor modifications to it and the T1R header is on the list of headers I was looking at. I was just wondering if it has thrown a CEL for anyone? I need to keep it off to pass emissions tests.
Old Jul 31, 2008 | 11:42 PM
Exclamation
The T1R header has a bung for the factory O2 sensor. I installed mine and no light.
HOWEVER: Depending on the inspector, and the regulations in your area, you may not pass the "visual" portion of the inspection. The inspector may decide you don't pass because you modified something between the engine and the catalytic converter. You can reduce the risk of this by somehow attaching the factory heat shield to the new header to cover it. One guy took it to a muffler shop and had them weld some threaded rods to it and bolted the heat shield on that way.
HTH
Old Aug 1, 2008 | 02:36 PM
Skierdood's Avatar
Thanks that helps alot! As far as hiding the header under a heat shield I'm pretty sure in NY as long as the stock catalytic converter is still in tact then it will pass, it just cant throw a CEL.
Old Aug 2, 2008 | 01:51 PM
No problem
If you've been helped, please don't forget to rep
SlowFit13
Dec 11, 2014 07:04 AM
jjboyes06
Jan 19, 2011 10:19 AM
xm8
Mar 26, 2010 01:13 PM
alexfree05
Apr 4, 2008 02:55 PM
garciabe
Sep 11, 2007 12:56 PM
