16*7 +38mm or <+38mm
Old Jul 29, 2008 | 07:56 AM
lilcat's Avatar
i'm running 16*7 +40, 205 45 16 and full coilover now. i think i can go to +36 or even <+36 and without rubbing, since i see there is a lot of space. any one got Photos of it or anyone try that before?
Old Jul 29, 2008 | 08:55 AM
GD3-Fit's Avatar
I <3 SPOON
of course you can!
with the coilovers it's ideal you can play with the ride height to make sure there's enough clearance to not rub
and if you have camber adjustment you're in the green
you should have little (if any) to no problems at all
-Ricky
Old Jul 29, 2008 | 05:10 PM
lilcat's Avatar
so what's my maximun offset can go.....+36? or <36
Old Jul 29, 2008 | 05:33 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
you can go way less than 36 if you really want to haha!
Old Jul 29, 2008 | 06:07 PM
EXWRX's Avatar
Which coilovers are you running?
Old Jul 29, 2008 | 06:58 PM
mahout's Avatar
How much are you lowered? Sounds like you have very little suspension travel at normal suspension set.
Old Jul 30, 2008 | 07:28 AM
lilcat's Avatar
i keep 2 fingers all round. and i feel like it can go more offset without rubbing.
Old Jul 30, 2008 | 07:31 AM
lilcat's Avatar
so what the lowest offset did you see be4? do you have any photo of it? i would like to go as low as i can
Old Jul 30, 2008 | 09:12 AM
GD3-Fit's Avatar
I <3 SPOON
well ray is running +25 offset with tein coilovers
he's got pictures everywhere you should be able to find it
i believe the thread is teaser coilovers, possums, and now enkei's
-Ricky
Old Jul 30, 2008 | 11:59 AM
mahout's Avatar
Two fingers what?
Tell us how many inches the top of fender arch is from the ground on all four corners.
Sorry to be short but this morning we had a fIT drop in here wanting to know why he was rubbing his 15" tires on his fenders; claimed he only dropped 1" and had offset of 38 mm. Turns out he had 36 mm offset and was dropped to where his fender arch was 22.5" from the ground.
He blamed Fit posters for his predicament; really upset by our advice to get new set of wheels with 45 mm offset.
Old Jul 30, 2008 | 12:35 PM
Fit4Trav's Avatar
Two fingers what?
wow....little upset...
I have a +13 offset, but I have 15x7.
Old Jul 30, 2008 | 02:03 PM
MNfit's Avatar
Two fingers what?
I think his car is dropped more then 1", I just measured my fender arch and with a 16" rime with a 45 series tire, lowered on Progress springs its 23.5 inches from the ground. What size tire is he running? The tire can make a big difference in whether or not you rub.
Old Jul 30, 2008 | 02:06 PM
mahout's Avatar
Sure you do. Thanks anyway.
Old Jul 30, 2008 | 02:25 PM
mahout's Avatar
You're correct: 205/50x15. He's lowered 2.5-3" and it rides like it. Wheel travel looked like it was maybe an inch based on extension of the piston rod.
The stock height from level ground to top of the fender arch is 25" front and 24.75" rear. When your height falls more than an inch below those you need 45 mm wheels to run 205 section tires with diameter 23.5" (stock is 23.44") without rubbing. You can get away with 38 mm offset and 195 tires but its close.
One car we tried with 195/60x15 tires (24.2" dia) rubbed like the dickens with 42 mm offset wheels.Sounds like MN runs 205/45x16 tires. What offset MN?
Old Jul 30, 2008 | 03:23 PM
MNfit's Avatar
You are correct about my tire size and the offset of the wheel is +42 mm. I have another set of wheels that are 15X6.5 with a +38 mm and has 195/50/15 tires on it and had no problems with rubbing. He should try running a 195/50 or 195/45 size tire. I'm not a 100% if that will solve the rubbing issue but I think it will realy help or he might have to by new wheels.
Old Jul 30, 2008 | 03:37 PM
Fit4Trav's Avatar
HKS Coilovers-still have about 1.5" in front to lower and about 1.5" in rear to lower. On stiffest setting.
SSR Reverse Mesh
15x7 +13
Rubs only on bumps and when I turn going up a driveway
Old Jul 30, 2008 | 05:56 PM
lilcat's Avatar
SSR Reverse Mesh
15x7 +13
nice!! maybe i will go to +30 if its no rubbing
Old Jul 30, 2008 | 06:54 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Id suggest +35mm as the lowest. 16in wheels are different then 15in wheels.
Im actually on Skunk2 coilovers, not Teins. My other wheels are 16x7 +35mm on 215/40/16's. My fenders are pulled and rolled so no I dont rub.
Josh (gd3kamiwanab) is on Tien coilovers. His wheels are 16x7 +35 with 205/45/16's.
He rubs a little
Old Jul 30, 2008 | 07:10 PM
mahout's Avatar
The small 195/50 or 195/45 tires fit OK but they are so small they not only look funny they yield 10% error in odo and speedo; on the worst side ( the readings will be higher than actual.
Old Jul 30, 2008 | 07:15 PM
mahout's Avatar
[quote=Fit4Trav;381124]HKS Coilovers-still have about 1.5" in front to lower and about 1.5" in rear to lower. On stiffest setting.
SSR Reverse Mesh
15x7 +13
13 mm offset from 55 means moving the outside tread edge of a 16x7 wheel mounted with 205 tires about 2" outward from the hub face which the wheels/ tires in your photo aren't. Check your offset. Worse even with the shown wheels/tires there has to be virtually no suspension travel to not rub considerably. Any time the tread area is under the fender arch all you do is make a big gokart.
cyanosis
20
Feb 11, 2014 03:24 PM
Burzpaw
Dec 9, 2011 03:20 PM
MarkB
Apr 16, 2008 04:43 PM
minitruckersfit
Dec 22, 2007 02:20 PM
GD3-Fit
Oct 15, 2007 07:25 PM
