Arrg! Broke lug nut stud!
Old Aug 10, 2008 | 06:33 PM
ricohman's Avatar
Originally Posted by pokems23
It seemed like an easy fix according to the DIYs I found online. Except when your working on a Fit!!!!! I tried to remove the screws on the rotor, but stripped the Philips head on them. So I drilled them out! YES! But then this happened when trying to remove the studs.
I don't have the tools or knowledge to remove the hub. Guess I'm going to have to fork out some dough at Honda to fix it.
Don't use a screwdriver on those screws.
Use an impact driver with some talc.
Old Aug 10, 2008 | 07:33 PM
Saved's Avatar
^^^ Bingo! I had to go buy one for around $15.00.
Old Aug 10, 2008 | 09:31 PM
Fa1's Avatar
Fa1
Might as well replace them with arp studs.
Old Aug 11, 2008 | 09:15 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
ARP's are way too long. If the OEM length is hard to put in ARP's would be death.
Old Aug 11, 2008 | 10:30 PM
Fa1's Avatar
Fa1
I'd go for open ended lug nuts anyways. And look on the bright side, you'll only have to put them in once
Old Aug 11, 2008 | 10:32 PM
Posts in the NUUDE
Unless you strip an ARP. Shit happens.
I dread removing my wheels everytime now.
I prefer open end also. Open end lets water build up and cause rust sometimes.
Old Aug 12, 2008 | 02:09 PM
pokems23's Avatar
June 2007 3rd Place Fit of the Month Winner
studs
So I brought my car to Honda and they deeply apologized. They got it fixed without an appointment. They made sure to tell the techs to torque it to 80 lbs.
Old Aug 12, 2008 | 02:14 PM
Saved's Avatar
Did you ask how much they would have charged you under normal circumstances? Just nice to know how much money I saved by doing it myself ya know.
Old Aug 12, 2008 | 02:18 PM
fork_nSpoon's Avatar
if you're gonna DIY do it proper, removed the hub and have a machine shop or somone press that shit out and press a new one back in.
Glad to hear honda got it fixed
next time you change your tires, it'll help if you throw some antiseize on the studs.
Old Aug 12, 2008 | 03:29 PM
wow, that does look like a pita to remove...
Old Aug 13, 2008 | 06:15 PM
swaknets's Avatar
replaced two front wheel bearings on my integra, had to separate hub and knuckle also, major PITA, got the harbor freight $120 12-ton press that helped a lot.
Old Aug 14, 2008 | 11:02 AM
  #32
pokems23's Avatar
I wasn't trying to do a DIY. I was trying to do a "Help! What the heck do I do now?" That would be great if there was a DIY on how to remove the hub.
Old Aug 14, 2008 | 08:41 PM
  #33
Posts in the NUUDE
Im curious as to what Honda would charge me to replace ALL my lug studs.
At least all 8 fronts.
Ughh... Thinking about doing this before my new wheels. Kinda want to run 5mm spacers.
Old Sep 2, 2008 | 09:23 PM
  #34
invaderzahn's Avatar
So I just did the same thing on my Rear Passengers side wheel. All the advice i've seen has to do with the Front wheels, since the rear wheels have different brakes is it easier or harder to fix? Any insight and/or pointers would be much appreciated.
Old Sep 2, 2008 | 09:28 PM
  #35
Posts in the NUUDE
The rears should be the easiest.
Remove the drum covers and the back of the studs should be seen easily.
One of my passenger studs is going to break. I tired to remove my front wheel last week. A few turns and it just stopped.
It was one I replaced too.
Old Sep 2, 2008 | 10:17 PM
  #36
kylerwho's Avatar
spoon fed
part number 31 is the wheel stud. just to give you an idea.
Old Sep 3, 2008 | 06:08 AM
  #37
chinese's Avatar
damn dude that sucks.. sorry that had to happen to you..
Old Sep 3, 2008 | 06:49 AM
  #38
Thanks for the quick replies everyone. I'm going to try to replace it today after work, I'll let you know how it goes.
Old Sep 3, 2008 | 12:33 PM
  #39
Tofuman's Avatar
as mentioned above, you should always use an impact screwdriver when removing the brake rotors. i learn this the hard way too.
i stripped a screw on my old '01 civic's brake rotor and had to drill it out. i got a ride to the hardware store and bought a $10 impact screwdriver on sale. it saved me a ton of time and it works like a charm.
if you haven't used one before, basically it's like one of those screwdrivers with several different heads that can be put in the tip. you line up the screwdriver into the screw, then you hit the back with a hammer. the screwdriver is designed to twist the tip when the back is hit with the hammer. it has a strong pushing force into the screw while twisting which prevents stripping.
Old Sep 3, 2008 | 08:46 PM
  #40
Talking
Gentlemen the operation was a complete success! Thanks for all your help and advice, the hardest part was getting the brake drum cover (part #3) off. after that it was cake.
