Sponsored by:
Sponsored by: CARiD
removal of a/c and powersteering belts
Old Aug 11, 2008 | 02:23 PM
bigcam112's Avatar
i was wondering if the removal of these belts would help in horsepower. i used the search button but nothing came up sorry if this is a repost... and if anyone has done could they please post some pics of what the belts look like and their method of removal.. thanks
Old Aug 11, 2008 | 02:36 PM
thomasgrant's Avatar
You should get to know your car a little better.
The Fit uses Electronic Power Steering and there is no belt to remove. It still uses a belt for the air conditioning system, however I can't see any benefit to removing that. It's not like it runs when you're not using the A/C.
Old Aug 11, 2008 | 02:52 PM
bigcam112's Avatar
oh sorry for not knowing the ins and outs.. but as with old honda hatchbacks and such you can remove power steering and a/c belts to gain a few horsepower. and with the a/c comment there is still drag created by the belt even while it is not operating slowing down the time it would take the motor to spin the belts
Old Aug 11, 2008 | 06:07 PM
CorrodesTheFilm's Avatar
Very little. If the compressor isn't engaged the engine is just turning the pulley on it's bearing. Also you'd have to re route the belt since it uses only one belt... something like this...
You'd have to make sure all the pulleys still rotate in the same direction, so you'd have to install another idler pulley in place of the A/C compressor. In which case you'll have...a pulley being spun on it's bearing with no load.
Old Aug 11, 2008 | 06:42 PM
bigcam112's Avatar
thanks for the answer
Old Aug 12, 2008 | 04:52 AM
drzenitram's Avatar
removal of all the AC parts and power steering parts(if they're bulky, I guess, I don't know anything about EPS) will result in weight loss, 40 lbs for the AC, not sure for the PS.
you can also remove the spare tire and tools for maybe 20-30 lbs in savings.
removing spare tire, passenger seat, rear seats, AC = 150+lbs weight reduction.
you know how much slower the car feels with a passenger? well, removing that stuff is basically like losing a passenger and dropping .5 seconds off your quarter mile
so, yes, you could see some gains if you did all that :-P
Old Aug 13, 2008 | 05:52 PM
Tofuman's Avatar
^ i think the AC actually weighs a little more than that. i think something like 55 lbs.
Old Dec 23, 2008 | 03:53 PM
bluerice's Avatar
The AC weighs 22lbs, I know cuz i removed mine and weighed it, and that's 22lbs for the AC lines, pump, AC condenser, and the difference in weight between the Fit sport belt and the Fit base belt, in a straight line you don't really feel the difference, but you'll immediately notice it in a corner, when you do remove it take the car for a test drive on some corners where you know how fast you used to be able to go around them and you'll probably be able to increase that speed 5-10km/hr depending on how tight of a corner it is, I didn't do the work myself so i don't have pics, but i went to a body shop to get it removed and it cost me $120 for 2 hours of labour.
Edit: I should note that your apex and exit speeds should be 5-10km/hr higher, but you may have to go a little slower into the turn since removing the AC also reduces the cars steering response a bit.
Old Dec 25, 2008 | 05:03 PM
FitPilot's Avatar
If you are that concerened about the minimal belt drag you need to move into a car with a bigger engine my friend.
Old Feb 21, 2009 | 08:51 PM
aallbbeerrtttttt's Avatar
hahaha wtf
grommet
Apr 27, 2026 09:57 PM
2010FITTY
Jan 23, 2020 06:10 PM
hstoynov
Jan 19, 2020 11:55 PM
Dave Z
Jul 2, 2012 09:44 PM
richardbentz@gmail.com
May 18, 2005 02:25 AM
