Smallest Drop
Old Aug 12, 2008 | 01:05 AM
Fit of RAGE's Avatar
Smallest Drop
Does anyone know who give the Fit the LEAST amount of drop with springs? I feel that with the stock suspension, the rears are WAY too soft. I'm rubbing on hard bumps and dips with 16" wheels while being in stock height. I'm hoping that with new springs, they'll be stiffer and will at least prevent the rubbing a little, until someone makes a stiffer shock for the rears.
Old Aug 12, 2008 | 03:05 AM
carramrod's Avatar
1st Gen Honda Fit Drop Spring Comparision
Name Part Number MSRP Drop Height F/R Spring Rate lb/in
Tanabe GF210 TGF122 $240 1.5/0.9 190/280
Tanabe DF210 TDF122 $220 1.8/1.3 173/274
Progress 40.106 $157.25 1.5/1.3 160/200
Skunk2 519-05-1750 $200 1.5/1.0 175/350
Eibach Pro Kit 4069.14 $230 1.6/1.3
Eibach Sport Line 4.694 $228 2.0/1.8
T1R S-Coil $251.99 1.6/1.4 179/341
Swift 4H017 1.4/0.8 168/313
may not be the best list but it seems to have some of the best.
Old Aug 12, 2008 | 03:45 AM
Fitcapo's Avatar
Doesn't swift have a 1.0/.08?
Old Aug 12, 2008 | 04:05 AM
Fa1's Avatar
Fa1
The J's racing dampers have a pretty small drop. 30mm front / 25mm rear if I remember correctly. You'll be getting performance out of it too.
Old Aug 12, 2008 | 05:28 AM
dagul's Avatar
Springs alone would probably be the swift springs as in terms of mildest drop. Full suspension (springs and dampers) would be the mugen, which I think is about an inch drop all around...
Old Aug 12, 2008 | 07:17 AM
vafit's Avatar
I have the swift sport springs with 16'' tires and have no rubbing issues at all. The springs have a drop 1.2'' front and 1'' back.
Old Aug 12, 2008 | 08:48 AM
thanks everyone!!
Old Aug 12, 2008 | 11:31 AM
you should just fix the area that's rubbing.
Saved
180
Jan 31, 2020 12:46 PM
Jhove
21
Jan 15, 2009 10:16 PM
Tiffany
29
Jun 23, 2008 10:01 PM
YeeFit
17
Apr 19, 2008 06:02 PM
fitfit123
May 12, 2007 02:05 AM
