my stock tires
Old Aug 28, 2008 | 02:46 PM
MemphisFit's Avatar
my stock tires
will my stock dunlops fit on a 15x6.5 rim???????????????? sorry if its stupid ive just never asked?
Old Aug 28, 2008 | 02:55 PM
mahout's Avatar
Its not stupid. Sure the rim width of 6.5" is within the accepted range for 195/55 section tires.
The more important question is whether the 15x6.5" wheels have the correct offset, hub bore, BC, and caliper clearance.
cheers.
Old Aug 28, 2008 | 03:05 PM
MemphisFit's Avatar
How can i find those things out? and what are the specs of the stock rim?
Old Aug 29, 2008 | 07:59 AM
mahout's Avatar
The stock wheel is 15x6", meaning the rim is 15" in diameter, measured at the base of the rim, not the flange, and 6" across inside the flange. Its where the tire seats on the wheel.
The bolt circle is 4 lugs 90 degrees apart on a 100 mm circle. Stock offset is 55 mm set out (meaning wheel hub is outboard of the car hub face); and the hub bore is 64 mm.
Clearance around the caliper is not a spec, you'll just have to find out yourself, usually by mounting just the wheel on the hub and bolting just as you would if it had a tire. Allow at least 1/8" all round even with wheel turned fully left and right. There are other things than the caliper to avoid. Especially if a tire was mounted, like a strut or trailing link. For stock tires it should be OK. And if you just want to widen the car consider wheel spacers from your local auto parts places at about $25. One quater-inch (6mm) spacers will move the wheels outward (track width)by half-inch, improving looks, and cornering, at little cost. Just make sure you get at least 7 turns on the lugbolts with spacers.
You can reduce offset to as little as 42 mm if youre not lowered, or to 45 mm if you are dropped no more than 1.5"
Good luck.
Old Aug 29, 2008 | 08:06 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
ohh noooo stock tires look so ugly on other wheels :/
but maybe you could do it?
Old Aug 29, 2008 | 12:44 PM
MemphisFit's Avatar
+1 mahout!!!
Old Aug 29, 2008 | 03:41 PM
ezduzit's Avatar
Good luck.
Hub bore on the stock wheels is 56.1 mm.
Old Aug 29, 2008 | 08:42 PM
fibinochi's Avatar
tires are the most important thing on a vehicle, i hate do use a definate statement such as that, but im sure few would disagree with that opinion. you may want to spend the extra money and pick up some good tires, just my perspective.
Old Aug 30, 2008 | 01:18 PM
mahout's Avatar
The only thing less expensive than a new set of GOOD tires that improve performance significantly is 1/4" spacers and the tires win on performance.
stephenmarklay
Sep 22, 2018 05:35 PM
littleblackcar
Oct 18, 2013 04:35 AM
strmslvrfit
Oct 20, 2008 03:46 PM
bread bucket
Sep 15, 2008 05:15 PM
Luichenwai
Aug 4, 2008 03:37 PM
