View Single Post
  #6 (permalink)
Old 09-05-2008, 03:59 PM
mahout mahout is offline
mahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to live
Quote:
Originally Posted by eldaino View Post
i still don't see how going above 48 is a no no. the stock offset is fifty flippin five!
there are a lot of guys dropped on konigs with a 40 offset who DON'T rub.
i say that as long as its 40 or above, you will be ok.
True, the stock 08 is 55 offset but we did run into a close clearance with 7" rims with 55 offset on turns based on our wheel gage.
There are also a lot of people with 40 offset who do rub. Whenever you see things like 'I don't rub but I drive over bumps slowly' they probably go rub in the nite or using narrow tires (like 195). To avoid having those things that seriously affect your Fit's resale value you need to avoid any rubbing. Period.
PS putting 195 tires on wider than stock wheels seems like a big waste. The whole purpose is getting more rubber on the ground.
