Pump Motor Water Windscreen Washer Problem
Old Sep 17, 2008 | 06:16 PM
tk_jazz's Avatar
Car is Honda Jazz , Uk 2003,
the front windscreen washer has stopped working, unlike in the past when tubes have been block, ive traced the problem, the symtoms are ;
No water being pumped to front washer when switch is pulled
Front motor not making any noise for front pump,
Rear washer works fine as the motor still make the noise when it pumps
ive checked for blockages in the rubber pipes , the switch maybe damaged ?, and or so im thinking the motor for the pump has failed ?
im taking for the circuit to be checked soon, honda have made the connection wiring for the front and rear motor pumps behind the front bumper different from each other which sucks, i dont thing theres a fuse, if there is a fuse the rear motor pump still works, kind off ruling a fuse problem out.
any advice before i by a new pump motor and last resort buy a new lever switch
Old Sep 17, 2008 | 09:42 PM
seeremlive's Avatar
Sent you a PM. Check the User CP.
Old Sep 26, 2008 | 04:16 PM
HONDAMATIC's Avatar
switch the connectors on both pumps, if the front ones work and the rears dont then the motor is bad
Old Sep 26, 2008 | 08:31 PM
tk_jazz's Avatar
hondamatic, i did take a look and clean the connectors on the motor pumps, switching may be difficult as i dont want to cut or damage the wiring,
im hoping the pump is damaged, as it would be easier to change the unit
Old Sep 26, 2008 | 11:33 PM
HONDAMATIC's Avatar
the pumps should have the same connectors.. or use a test light
Old Sep 27, 2008 | 10:51 AM
tk_jazz's Avatar
last i checked, the connector blocks are different on each pump
Old Sep 29, 2008 | 04:43 AM
HONDAMATIC's Avatar
oh really, darn.. usually thats how i test mdxs, integras etc at work
Old Oct 3, 2008 | 08:41 PM
CuTeBoi's Avatar
Thought they were just different colors...
Use the test light to find out if there is power when the switch is being pushed.
Old Nov 6, 2008 | 08:14 AM
tk_jazz's Avatar
test the circuit and power is coming in to the pump,
within 4 weeks now the rear pump has also stopped pumping,
still cant find the fuse for the pumps
winters crept in now, so really could do with these fixing before it snows !
Old Nov 6, 2008 | 12:59 PM
Rob22315's Avatar
If there's power at the pumps and the ground is good, you need new pumps. A loose ground will take out an electrical device too.
Check both sides of the circuit to make sure something isn't loose. Also, take a pump out and hook it directly to 12v. If the pump runs, the problem is in the wiring, switch or fuse.
Old Nov 6, 2008 | 03:09 PM
tk_jazz's Avatar
were is the ground usually found?
Old Nov 8, 2008 | 06:23 AM
Rob22315's Avatar
I don't know where it is for this component. Someone with a wiring diagram will have to help. There are usually a couple of spots around the vehicle where bundles of wires are attached to the frame of the vehicle. The easiest way to check is with a continuity tester or ohmmeter. Just touch the wire or connector and the frame with the tester.
If you or a friend has a decent multimeter, it should be easy to check for 12volt power and good ground.
Dizzy5
Feb 22, 2018 09:23 PM
dieselanc
Sep 12, 2017 10:32 AM
egvtec
Jan 20, 2013 11:12 AM
GaryMD
Jul 11, 2011 05:08 PM
R8EDXXX
Jul 11, 2005 09:18 AM
