Wiper switch testing
Old Aug 26, 2017 | 04:28 PM
dieselanc's Avatar
I was hoping someone here could tell me how to test my 2010 Fit Sport wiper switch. As I have no washers front or rear. First thing I checked was the fuse and it is good. I can't see both washer motors going out at the same time. So that is leading me to the switch.
Thanks
Tom
Old Aug 26, 2017 | 07:22 PM
ezone's Avatar
Washer tank isn't just empty? (don't laugh)
There is only a single washer pump that runs both front and rear washers.
Access the pump motor and wiring, probably by peeling back the inner fender trim. (or however you need to access it...I don't have a similar car to look at in front of me)
Connect a test light to the wiring for that washer motor. Pull the trigger on the washers and see if the test light lights up. (or use a voltmeter)
If it lights up, that confirms you have both power and ground TO the pump, therefore the pump motor must be bad.
If it does not light up, you have more sleuthing to do.
Old Aug 27, 2017 | 03:06 PM
dieselanc's Avatar
Smile Switch testing
According to all the info about my car it has two pumps one for each end.
That is why I was headed towards the wiper switch as I can't see both pumps
going bad at the same time. And just for S and G I am going to pull the inner fender and inspect maybe I will get lucky and just have to plug them back in.
Old Aug 27, 2017 | 03:27 PM
ezone's Avatar
You need to find better info then LOL
It has a single washer pump.
Old Aug 28, 2017 | 05:02 AM
Black3sr's Avatar
  1. Remove the right inner fender.
  1. Disconnect the 2P connector (A) from the washer motor (B).
  1. Test the motor by connecting battery power to the No. 1 (or No. 2) terminal, and ground the No. 2 (or No. 1) terminal of the washer motor. The motor should run.
    • If the motor does not run, or fails to run smoothly, replace it.
    • If the motor runs smoothly, but little or no washer fluid is pumped, check for a disconnected or blocked washer hose, or a clogged washer motor outlet.
Old Sep 11, 2017 | 04:51 PM
Mitch101's Avatar
Anybody know if the washer pump sends water to the rear by *reversing* the impeller blades? Mine only sends to the front, and the impeller only rotates clockwise no matter what I do at the control arm by the steering wheel. When I swap the tubes, it sends to the rear no problem. So is there a relay that tells the pump to turn clockwise or counter-clockwise? Do I have a bad relay? The pump works fine but only spins in one direction.
Old Sep 11, 2017 | 09:05 PM
ezone's Avatar
On a system with a single pump, polarity is reversed to make the motor run the opposite direction to force fluid to the other line.
Polarity reversal is controlled by the MICU.
I'd suggest you could check the pumps harness connector with a voltmeter to see if the unit is in fact receiving power AND ground when each direction is requested (watch the polarity closely).......and then check the pump itself-use jumper wires to manually apply power and ground to the pump motor....then switch wires to change the motor direction, to see if the pump does or does not run both directions.
A pump is a whole lot cheaper than a MICU...
Old Sep 12, 2017 | 07:12 AM
Mitch101's Avatar
Many thanks. I did check the connector with a voltmeter and got +12V but forgot to tell the wife to activate the rear washer for a 2nd voltmeter check. I also disconnected the battery for 20 minutes hoping to reset the MICU (if such a thing's possible) with no effect. What makes you think it's the MICU and not a relay somewhere?
Old Sep 12, 2017 | 10:32 AM
ezone's Avatar
Read again....I did not say that.
Because there are no relays involved in your issue.
dwiebe
Jul 11, 2022 08:09 PM
Santiad
Jan 11, 2015 11:42 PM
natepartlan
Aug 12, 2009 02:01 PM
Squawking7500
Feb 4, 2009 08:38 AM
gts1985
Jan 14, 2008 01:22 PM
