Cruise control not working....after ground wire kit install...???
Old Sep 24, 2008 | 04:15 AM
FELIXY69's Avatar
so after installing my grounding cables.....my cruise control doesn't work
what's the first thing to check ? fuse? where ?
the problem now is the light for cruise control lights up BUT it doesn't SET the speed
thanks
Old Oct 4, 2008 | 02:09 AM
kylerwho's Avatar
spoon fed
my guess would be a bad ground connection. maybe recheck all the wires and make sure they are tight and clean.
Old Jan 29, 2009 | 11:09 PM
*Garismatic*'s Avatar
Didja figure it out?
Old Mar 10, 2009 | 02:23 AM
robcollins5's Avatar
Same Issue
I have not yet done the grounding kit, however my cruise control also stopped working. The "Cruise Control" light in the dash comes on, but the one to the right of it...I forget the title since it won't come on now (lol)...does not come on when I press the Set button and CC obviously doesn't work. I'm no electrical novice, so I'm more than happy to try out any ideas. I've done A LOT of aftermarket electrical additions to my vehicle, so the possibilities are endless.
rc
*Edit* Just put sig together to list electronics.
Old May 13, 2009 | 04:24 PM
Fix!
Sorry it's been so long for a response, but I found the problem on my fit. I had installed an after-market horn. The horn shares the relay with the Cruise. The new horn blew the relay which also killed the Cruise. The relay can be found in the control box under the hood. There are four in a row and the one you want is second from the front of the car.
*Front Side* 1, 2, 3, 4 *Firewall Side*.
This part is $23 at your local dealer or $7 at an online dealer/parts distributor.
rc
Old Jun 16, 2009 | 04:53 PM
viperjh16's Avatar
is there a different with the kit i was thinking for doing it i got the part to do it 4 GA amp wire and im waiting for my order for the terminal rings to come in
Old Jun 27, 2009 | 08:18 AM
FELIXY69's Avatar
how do i check if mine is blown ? u can't see the inside of it cuz it's all black !!!
GinoLicious
Jul 26, 2024 10:31 AM
degnaw
Jul 6, 2018 11:58 AM
sdavid12
Dec 4, 2017 08:11 AM
robcollins5
Nov 8, 2014 01:45 PM
marklj
Oct 7, 2014 02:14 PM
