Honda Fit Sidemarker Template
Old Nov 3, 2008 | 11:48 AM
  #121
accordguyintake's Avatar
yo dan when are we doing another wrench meet? Oh eddie i'll neeed ur expertise again as well as Jordan (Fitzee) made me go for some clearrs! I'll settle for turn only but i cant wait to see if you're gonna come up with a crazy wiring setup
Old Nov 3, 2008 | 02:18 PM
  #122
gimme's Avatar
Master FitFreaker
the next one is at Pann Auto. Eddie figured out how to have the signals lit and function as a blinker...pretty trick! For straight lit or blinking, I can do that.
Old Nov 3, 2008 | 02:30 PM
  #123
Lunar_GD3's Avatar
Yea I can help you out, next meet im bringin my girls Si for some sidemarkers. as for some crazy wiring, wait til you see what I got in store for jordan. Itll be cool as shit if I can get the time to make it.
Thanks man It's always nice when your work is appreciated. As I said above, wait til you see what Im going to try with jordans wiring, that'll be slick. but unfortunately I wont be attending the pann meet. So maybe the next one I can.
Old Jan 7, 2009 | 01:59 PM
  #124
mikejet's Avatar
So I'm new here. Where do I buy side markers and their wiring harness so I can find help installing them?
You're cars look great with the makers on!
I live in West Covina.
Old Jan 7, 2009 | 07:59 PM
  #125
gimme's Avatar
Master FitFreaker
JDM Honda Parts, JDM Honda Engines / JDM Nissan Motor Swaps, Used JDM Parts - Password JDM
we use the DC5 markers with harnesses
Old Jan 21, 2009 | 12:20 AM
  #126
VBP08GD3's Avatar
if this is still around can some one send me the template and wiring DIY
waste16pads@gmail.com
Old Jan 21, 2009 | 07:18 PM
  #127
gimme's Avatar
Master FitFreaker
just sent the template. wiring is easy...once you get under there, you'll get it
Old Jan 21, 2009 | 10:34 PM
  #128
VBP08GD3's Avatar
thanks alot bro... + rep
Old Jan 21, 2009 | 10:35 PM
  #129
VBP08GD3's Avatar
so wait i am cutting the whole in the dashed lines or solids
Old Jan 22, 2009 | 12:49 AM
  #130
gimme's Avatar
Master FitFreaker
solids....you want to cut INSIDE the solids
Old Jan 22, 2009 | 10:17 AM
  #131
VBP08GD3's Avatar
so basically i tape up the fender
put template on top of fender trace the inside and cut?
Old Jan 22, 2009 | 11:19 AM
  #132
gimme's Avatar
Master FitFreaker
yep. I lay dow 2 strips of 3" blue or green painters tape then trace the template.
Old Jan 22, 2009 | 01:38 PM
  #133
kenoshainflames's Avatar
could you send me the template? i really want amber ones for my fit
Old Jan 22, 2009 | 02:35 PM
  #134
gimme's Avatar
Master FitFreaker
PM your email and I'll get you it tonight
Old Apr 19, 2009 | 12:44 AM
  #135
phoryu2nv's Avatar
where can I get the bulb and socket from, thanks!
Old Apr 19, 2009 | 12:59 AM
  #136
gimme's Avatar
Master FitFreaker
Honda has them. Go in to the dealer, hit the parts/service counter...and ask for the bulb and socket for a DC5 aka RSX
Old Apr 19, 2009 | 01:02 PM
  #137
VBP08GD3's Avatar
bulbs are like 2 bucks at any autozone or advanced autp parts store the socket u can get it at honda
Old May 10, 2009 | 01:31 AM
  #138
fitmobil's Avatar
Originally Posted by Lunar_GD3
Relay or a dual filament bulb( not available in this size from my research) are the only two ways to get that result.
Try this, it calls reverse grounding - one wire from side marker connects to parking light positive wire and the other side marker wire connects to signal positive wire. Then you don't need to use relay or dual filament bulb. It should work. Someone needs to test it out and report.
Old May 10, 2009 | 03:21 AM
  #139
VBP08GD3's Avatar
Thats the way mine are wired..they are great no probs
Old May 10, 2009 | 01:13 PM
  #140
gimme's Avatar
Master FitFreaker
so ground to pos, pos to ground?
