Honda Emblems, RED emblems, CF emblems, emblems questions
Old May 22, 2006 | 01:21 PM
  #41
geedee's Avatar
the dot on the Fit and the dot on the Jazz are different in size..
so u may want to get the red dot from the Fit badge
which is sold in japan
the fit is known as jazz outside of japan besides NA
Old May 22, 2006 | 02:03 PM
  #42
aziatiklover's Avatar
Master FitFreaker
thanks for the infos but how different r they?? bigger dot??
Old May 22, 2006 | 03:38 PM
  #43
Ultimat451's Avatar
I saw on collegehills the jazz emblems and the red comes with the chrome emblem and the blue with the brushed aluminum. What is on the NA fit? Is it chrome or brushed aluminum?
Old May 30, 2006 | 06:34 PM
  #44
sillypuddy's Avatar
Someone that Posts too much
JDM emblems and coin holder
Just got my shipment from AJR, excellent vendor..
Before emblem install:
After emblem install:
JDM coin holder installed:
A few comments about the emblems..
I used:
EP3 front red emblem
DC5 rear red emblem
the front one is about 1cm too small all around, I wasn't sure if there was another one that would fit better, but you won't notice it until you get reallly up close
the rear one is perfect sized
in both cases, the pegs from the JDM one don't line up with USDM (in my case, Canadian) cars.
for the front, I used a small screwdriver wrapped with a shop towel and slowly pop it out, it came out pretty easy, no tape is used in the factory install. Then I used a pair of cutters and took out the peg right from the JDM emblem. Then I took the dremel and remove the two nipples that is left over when on the grill. If you don't take out these two nipples, the emblem will not sit flush with the grill.. you can dry fit it first and you will know exactly what i mean.
for the rear, it's a different story. It took me and my mechanic about 1 hour to just remove the factory emblem. the peg was stuck in the body pretty good and the way there is a "lip" around the emblem, meant that we had to be extra careful not to scratch the paint. we ended up using our spare credit cards as "paint guards" for our small screwdriver and putty knife (put them under the screw driver and putty knife to protect your painted "lip" around the emblem) and we worked the two pegs back and forth and EVENTUALLY it will snap.. we cleaned off the remaining peg sticking out of the body with a dremel. the JDM emblem again has two pegs that won't fit.. the white pegs you can pull out with a pair of pliers, the remaining nipple, work it the same way as the front, sand them flush with a dremel.
total time spent: 1.5 - 2.0 hours, less if you just snap the stock emblems instead of removing it like i did
jdm coin holder.. remove the blank switch plate and just install it.. 30 seconds
-joe
Old May 30, 2006 | 08:06 PM
  #45
Master FitFreaker
wow looks very nice man thanks for the write up as well
Old May 30, 2006 | 08:11 PM
  #46
sillypuddy's Avatar
I figure it will save somebody some headaches down the road.. it's not exactly a "drop in" replacement..
-joe
Old May 30, 2006 | 11:08 PM
  #47
kentris's Avatar
Actually, there's a much simpler method of removing the rear badge.
If you look under your rear boot handle, there's a small gap. Between that gap you should be able to see the 2 pegs that hold the badge inside.
All you need is a ruler with the little hole in it (which is normally used to hang rulers up in the shop) and then hook it and then pull down with enough force and the peg should snap off
Old May 30, 2006 | 11:32 PM
  #48
sillypuddy's Avatar
doh.. if i knew that i would have done that
-joe
Old May 30, 2006 | 11:43 PM
  #49
kentris's Avatar
Yeah I didn't know about it either until my friend did it on his 1.4 iDSi. He was just washing his car one day and notice that there was a gap between the rear handle and the panel.
He got his badges changed recently.
Old May 31, 2006 | 12:38 AM
  #50
Jazz it up!'s Avatar
Why is it that you don't use the same emblems on the front & rear?
Old May 31, 2006 | 01:15 AM
  #51
geedee's Avatar
because they are different in size
front one is larger than the rear
Old May 31, 2006 | 02:06 AM
  #52
STTICH's Avatar
looks heaps better
Old May 31, 2006 | 02:21 AM
  #53
bucketheadFIT's Avatar
looks pretty cool!(i havent seen how these badges attach but i know that on older model Hondas..ive always used dental floss to get behind the emblem and then pull it off..if it was on there pretty good this method may not have worked)
Old May 31, 2006 | 02:40 AM
  #54
Paulo107's Avatar
the emblems give it a nice touch
Old May 31, 2006 | 06:41 AM
  #55
sillypuddy's Avatar
the stock emblems weren't taped to the body like the older hondas
both front and back were held on by the pegs.. and the back was a son of a biatch to get out
-joe
Old May 31, 2006 | 08:32 AM
  #56
Mugen_Dom's Avatar
Looks good!!
The coin tray was easy peasy to install....just be glad we have the fuse box there otherwise it might not have been!! I've been thinking about replacing the rear emblem, but then again, i'm worried that it'll just tempt someone to rip it off!!
Old May 31, 2006 | 08:57 AM
  #57
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
looks good man..
but last time I used that little storage place where the rag is I thought I lost my phone and spent like 3 hours looking for it.... lol
Old May 31, 2006 | 01:01 PM
  #58
Packy's Avatar
Frequent FitFreak Poster
Originally Posted by sLiVeRwOrM
looks good man..
Heh! Our Forester has a storage spot there, but it has a flip-down door... I completely forgot about all the atomic fireballs we put there until I opened it the other day. Great for "secret eating" (points if you name where the quote is from!)
The red emblems look great, BTW! Those should look slick on silver and black Fits, too.
Old May 31, 2006 | 02:37 PM
  #59
corey415's Avatar
Even though I probably wouldn't use it, I just love that JDM coin holder!
Old May 31, 2006 | 08:00 PM
  #60
sillypuddy's Avatar
as you can see, i already got coins in there
i find that if you put the coins down under, you have to reach down and sometimes at hard cornering, they "jump" out
it stays pretty well in the coin holder
-joe
