The Mysterious Blue Glow- LEDs Installed
Old Nov 22, 2008 | 09:58 PM
TFB Designs's Avatar
I ordered two LED light tubes and installed them under the dash. The light tubes are hidden out of visibility. I will be adding a switch soon.
I'll make a DIY for the lights and the switch if people are interested.
Old Nov 22, 2008 | 10:44 PM
Rubba Burna's Avatar
HID Addict
im interested.. if its a automatic turn on when the door opens. and if its white/blue white. how much was it each and can it be put in the back?
Old Nov 22, 2008 | 10:52 PM
To make the lights come on only when the door is open you would just have to tap into the fuse for the dome light. I will explain how to do this if I make a how to. I'm sure you can find white LEDs. As for installing them in the rear you will just need extra wire. I paid $28 including shipping from eBay user hwy836. I bought two 12" LED tubes
Old Nov 22, 2008 | 11:04 PM
Old Nov 23, 2008 | 12:49 AM
ofit's Avatar
pls do
Old Nov 23, 2008 | 10:57 AM
manxman's Avatar
Nice job, Tim. I am looking forward to your DIY too. Thanks in advance--
Dave
Old Nov 23, 2008 | 07:25 PM
Special's Avatar
Im pretty sure their are write-ups on wiring it to the dome light. Ive been debating if i really wanna do it. And Oznium.com sells them, ive only heard good things about them
Old Nov 23, 2008 | 10:48 PM
hondajazz2005's Avatar
that is really nice DIY. thanks for your writeup !!!
Old Nov 23, 2008 | 11:35 PM
Fitftw's Avatar
interested in the DIY
Old Nov 24, 2008 | 12:06 AM
Simple DIY
Here is a simple DIY. I will go into adding the switch and making the lights come on when the door is open after I add a switch. The first thing you need to do is mount the lights. Each light tube comes with two tiny screws. You can make a pilot hole for each screw using a push pin. The plastic is thin so the push pin goes through easy. Here is where I mounted the lights:
Keep in mind that I had to hold the camera at a very low weird angle to see the lights. The light tubes are not visible at all when inside or standing around the car.
Then I bought a splitter for the ciagarette lighter power adapter and double stick taped it to the inside of the glove box.
The wires are hidden behind the dash and plugged into the 12v power source.
Old Nov 24, 2008 | 12:08 AM
Toggle switch DIY coming soon.
Old Nov 24, 2008 | 12:13 AM
Fitftw's Avatar
ah so you bought a spliter for the ciggarette lighter. i was wondering how much managed to do that. + rep on the DIY !
Old Nov 24, 2008 | 12:22 AM
Yes^ and I bought a 3-way splitter so I can charge the GPS or cell phone. I am going to wire the switch to the cigarette lighter adapter.
Old Dec 3, 2008 | 06:04 PM
Interstate526's Avatar
looking forward to the toggle switch!
Old Dec 3, 2008 | 10:25 PM
saiko's Avatar
Avid FitFreak Poster
Check out the dome light thread. It's really easy to hook up these lights to work with dome light rather than using an external power source.
Old Dec 3, 2008 | 10:31 PM
Me too! It's coming soon.
Old Dec 4, 2008 | 10:15 PM
I ordered a toggle switch with a blue LED. I also picked up some fuse taps today. DIY coming soon.
Old Dec 15, 2008 | 07:18 PM
redhatyellow2's Avatar
Will this work on an '09 model as well? I'm thinking of doing this!
Old Dec 15, 2008 | 08:05 PM
Yes the lights and adapter will plug into any vehicle with a 12v outlet or a cigarette lighter.
Old Dec 15, 2008 | 09:37 PM
I meant: Will I be able to hide the wires behind the dash in the 09 model? And the glove as well? Sorry, this will be my first car !
