How to reset SRS Airbag indicator light. It works too.
Old Dec 4, 2008 | 09:45 AM
bosshogg's Avatar
Ok, this works 100%, i know because i've just done it on my 2004 UK version Jazz/Fit, hope it helps someone.
YouTube - How to reset SRS Airbag indicator light
Old Dec 5, 2008 | 10:54 AM
D50boy's Avatar
I've used that before on an Accord and a Prelude. It works.
Old Dec 10, 2008 | 09:01 PM
pb and h's Avatar
paper clip
Old Dec 10, 2008 | 09:12 PM
kelsodeez's Avatar
UNBANABLE
sooo if you have seats and a steering wheel, does this keep the light off?
Old Dec 11, 2008 | 02:20 AM
kylerwho's Avatar
spoon fed
that airbag light on the dash is what is holding my back from doing aftermarket seats. i get annoyed with little lights going off everywhere.
Old Dec 11, 2008 | 03:09 AM
Spooling's Avatar
will try it
thanks
Old Dec 11, 2008 | 02:58 PM
Fa1's Avatar
Fa1
It will come back on.
Old Dec 11, 2008 | 03:02 PM
towelie's Avatar
iHardpark
i go the same question??? but if it comes back on can i just keep resetting it
Old Dec 21, 2008 | 05:47 PM
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
airbag light
what happens if the airbag light is on? if 1 bag is missing/disabled will the other bags still function properly?
Old Dec 22, 2008 | 10:45 AM
zulkifli buang's Avatar
Mine Honda Fit 2004 JDM version. What MES? WOnder will the airbag be deployed?
Thks in advance
cheers
Old Jan 2, 2009 | 02:54 PM
SFactor2's Avatar
so it's 100% for the uk version (only 2004)
NOT 100% for usdm
try not using fancy math jargon like "100%".....instead just state that it worked on YOUR car not every car in the universe and let the reader come to there on conclusions
Old Mar 18, 2009 | 07:41 PM
Daemione's Avatar
No, this'll just reset the light. If you're still missing the airbag, the light will come right back on.
Sure . . . if you don't mind doing this procedure every time you want to drive your car.
If you remove an airbag and want to keep the warning light from coming on, you need to trick the computer into thinking the airbag is still there. So take a multimeter and measure the resistance for the airbag that you've disconnected. Then go to radioshack and find a resistor that matches - and use that resistor to trick the computer into thinking there's still an airbag there.
Please note: I'm not advocating doing this, just saying that if you wanted to, that's how you'd go about it. Playing around with a multi-meter around an airbag can be DANGEROUS.
As far as I know, this is standard procedure for resetting the airbag light in every Honda that has them . . .
Old Jul 11, 2009 | 05:01 PM
olgazagariya's Avatar
Srs, airbag, maintenance required lights reset free
Here is some helpful info.
The following site is one that I always use. They have FREE instruction videos to reset your srs, airbag, maintenance required, brake and other lights. Instead of paying a dealer hourly you can find info for FREE without using a scanner. Another cool thing they have is new parts from the dealer with up to 40% discount. Check it out.
www.vehix411.com
Old Sep 29, 2009 | 08:44 PM
gldf111's Avatar
2009 Honda Fit airbag light reset.
Hi, Anyone knows how to reset the airbag light on a 2009 Honda Fit? I looked under the dash for the yellow MES connector, as posted in other threads, but there's no yellow connector there. Thanks for any help.
Old Oct 12, 2009 | 06:38 PM
Daemione's Avatar
My GD has the yellow connector in the fusebox area, it wasn't hard to find. I'd be surprised if the GE's was much different . . . but I've never looked in one.
Old Jun 12, 2011 | 06:09 AM
damoaten's Avatar
Hi-Trying to reset the SRS light on a 1996 Honda Fit. I am trying to find the yellow connector. There are loads of connectors which are plugged into my fuse panel. However, none are hanging down loose.
Secondly, my car is a Japanese import with a radio set up for the Japanese market. Is there any way of resetting the radio for the European market? I wonder if anyone can help? Thanks
Old Nov 20, 2012 | 06:20 PM
T-Fit's Avatar
Old thread. But yes. This does work to reset the airbags on an 07 USDM Fit. Though I am still having problems getting resistors to properly bypass the airbags after installing my Type R Recaro's.
I unplugged the battery, let sit for half an hour. Installed my Recaro's, put 5 watt 2.2 ohm resistors in the seat side airbags plugs, connected all other remaining plugs back how they were, connected the battery, reset the airbags, reconnected the MES plug, started car and the light came back on.
Old Jul 14, 2013 | 07:56 PM
swade's Avatar
Any updates to this info?
Old Jul 14, 2013 | 10:16 PM
13fit's Avatar
the almighty GOOGLE showed this for a honda S2000 but honda uses a similar module across its models
HB1320
Feb 27, 2014 07:43 PM
greyfox
Jul 29, 2010 05:53 PM
Batman
Dec 15, 2008 03:01 PM
bosshogg
Aug 31, 2008 05:17 AM
Thor28
May 16, 2007 01:54 PM
