Will adding bride seats disable all airbags
Old Feb 21, 2014 | 08:08 AM
HB1320's Avatar
I heard from a friend that once I unplug the airbag switch from the front seats once they are removed that a airbag light will show up on the dash and it won't only just be on it will disable ever single Airbag in the car. True or not?
Old Feb 21, 2014 | 02:04 PM
ikutoisahobo's Avatar
If the airbag light comes on, then I'm guessing the computer automatically thinks the airbags are deployed? Maybe?
Not sure.
Old Feb 21, 2014 | 06:57 PM
HB1320's Avatar
Originally Posted by ikutoisahobo
If the airbag light comes on, then I'm guessing the computer automatically thinks the airbags are deployed? Maybe? Not sure.
That's my questions lol I guess it's yours too
Old Feb 21, 2014 | 07:05 PM
No, that's my answer with a question inside of it. lol
I'm sure you could try to unplug the SRS thing and see if the SRS light comes on.
Or you could maybe rip apart (okay, so you probably won't have to rip them apart) the seats and take the airbag 'unit' which the wire plugs into and keep that under your new seat?
Old Feb 22, 2014 | 12:08 AM
HB1320's Avatar
I wouldn't want to keep the 'airbag' unit under the seat though Bc it would deploy right?
Old Feb 22, 2014 | 01:13 AM
Only if you crash. It's a curtain airbag so it shouldn't blow your bottom off.
Old Feb 25, 2014 | 11:34 AM
swade's Avatar
You can get resistors to plug into the plugs for the airbags on the harness side to make the srs ecu think there are still airbags present, this also allows the other airbags to function properly.
Old Feb 25, 2014 | 03:57 PM
mahout's Avatar
And of course the airbag warning light will display.
Don't know if all airbags are deactivated but the passenger seat will if the sensor doresn't think there is anyone in the seat.
Will your state's vehicle inspection be a problem?
Old Feb 25, 2014 | 05:08 PM
HB1320's Avatar
Where can I find that! That would be the ideal thing to do
HB1320's Avatar
Originally Posted by mahout
And of course the airbag warning light will display. Don't know if all airbags are deactivated but the passenger seat will if the sensor doresn't think there is anyone in the seat. Will your state's vehicle inspection be a problem?
It won't be a problem I'm in FL
Old Feb 27, 2014 | 07:43 PM
swade's Avatar
Need help getting rid of SRS Light with 2.2 OHM Resistor - Honda-Tech
2.2ohms From this thread. I don't know for sure which pins though, might have to look it up in a FSM.
swade
bhacker1994
Apr 20, 2016 12:25 AM
wlfit
Mar 25, 2015 05:46 PM
bosshogg
Jul 14, 2013 10:16 PM
lovelyfit
Jan 12, 2012 06:14 PM
lovelyfit
Mar 3, 2009 12:34 AM
