It broke!!
Old Dec 14, 2008 | 05:46 AM
chinkyy's Avatar
It broke!!
while i was installing my quick shifter i broke this off
<img src="http://www.aj-racing.com/ajpwr/Fit/install3.jpg"/>
does anyone know what this is called???? thanks
Old Dec 14, 2008 | 09:39 AM
Carbuff2's Avatar
I can't tell exactly, but at worst you are looking at the entire shift cover assembly #3, which sells for $25 - $35.
If you are lucky it's the Dust Cover # 11, less than 5 bux.
Old Dec 14, 2008 | 01:29 PM
kylerwho's Avatar
spoon fed
did you just break one of the arms off? its not that big of deal. just put the borken one back in when you install it and the other clips should hold the shifter assembly in place.
Old Dec 14, 2008 | 02:50 PM
chinkyy's Avatar
ya im talking about the white thing that goes around the ball that kinda holds the shift lever in place. (it also took a while to get out) luckily that guy didnt break it into pieces i have about 3/5 of it left. so when im in neutral and i move the shifter to the left it kinda just stays there a bit but when i move it to the right it moves back
does anyone know what that piece is called????
Old Dec 14, 2008 | 03:10 PM
kylerwho's Avatar
spoon fed
a new assembly costs 88 dollars. you cant buy that little holder seperately unfortunately
Old Dec 14, 2008 | 03:16 PM
chinkyy's Avatar
awww man but do u think i can live with only 3/5 of that nothings would go wrong right???
Old Dec 14, 2008 | 03:27 PM
kylerwho's Avatar
spoon fed
as long as it holds the shifter lever in place and doesnt make you miss your shifts then i would not worry about it. maybe its a good excuse to buy the mugen short shifter assembly. ha ha ha
Old Dec 14, 2008 | 04:13 PM
Carbuff2's Avatar
You could try cramming dense foam (like the stuff used for packing computers) into the area where the claw is missing. This would provide support and a little springing, self centering action.
Kind of Ghetto, but it would work as long as it isn't deteriorated by oil. It hides under the shift boot, correct?
Old Dec 14, 2008 | 04:46 PM
chinkyy's Avatar
i was going to sell the lever and buy the mugen one but we already got so far cuz this took us 4 hours -_- due to my lack of research
i mean it works im gonna try to put the other piece back on i also lost some of those plastic tabs for the center console too man you always lose those little tabs
Old Dec 14, 2008 | 08:40 PM
trancedsailor's Avatar
If it's not an easy fix, go ahead and get Mugen lol
Old Dec 15, 2008 | 01:45 AM
Im|Inside|Fit's Avatar
i dont know what to say but hey it broke for some good reason i think its meant for you to get the mugen =P good luck on fixing it =)
strmslvrfit
May 25, 2009 03:54 PM
xanatos
Aug 26, 2008 11:06 AM
kylerwho
Aug 12, 2008 03:44 AM
sethne
Jul 10, 2008 09:58 AM
rabidmechanic05
Dec 22, 2007 01:22 PM
