b pipe ground clearance question
Old Dec 17, 2008 | 05:43 PM
isthata_scion's Avatar
anyone know off of first hand which b pipe has more ground clearance between the aspec or T1R? or is there not enough of a difference to even matter?
Old Dec 19, 2008 | 10:18 PM
grtpumpkin's Avatar
If I remember correctly it is the Megan Racing b-pipe that has the oval resonator and therefore, more ground clearance. Between the A-spec and the T1R I think they are the same as the OE. I might be remembering it wrong though....
Old Dec 19, 2008 | 10:56 PM
explosivpotato's Avatar
The Megan Racing b-pipe does not have an oval anything.. The resonator is a circular can.
That said, I don't notice it sitting lower than stock.. Maybe 1/2-3/4". Certainly not enough to cause a ground clearance issue, both with my stock cat and with the cat-delete downpipe.
Old Dec 19, 2008 | 11:00 PM
kylerwho's Avatar
spoon fed
the j's has no resinator and is just striaght goodness if your worried about ground clearance. all other ones are build the same and ground clearance is not to much of an issue with the aspec, t1r, or megan.
Old Dec 19, 2008 | 11:28 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Aspec hangs stupid low. I used a clamp to pull the exhaust up. I kept the rubber in place, wrapped a worm clamp (hose clamp) around the hangers located in the center of the passenger front door.
Tighten it up so that there was barely any clearance between the floor and B-pipe.
Gave me at least 1in more of clearance.
I still scrape and mash things with my exhaust.
Old Dec 19, 2008 | 11:30 PM
kelsodeez's Avatar
UNBANABLE
the T1R hangs really low too. i thought there was something wrong with it when i first put it in but thats just the way bpipes for the fit go i guess.
Old Dec 20, 2008 | 04:03 AM
FitVic's Avatar
Jesse if you remember how low mines hang that was the Megan B Pipe. After talking with Ray I'm gonna take his advice and do the same to pull it up. Lately I've stratched my resonator about 4 times in the past 2 weeks. Before that like 2 months before lmao. I honestly think my Megan B Pipe hangs stupid low. So low that from a side shot you can see it.
Old Dec 20, 2008 | 11:40 AM
haha yeah vic i remember just looking at the resonator standing at the side of your car.
Id love the J's but im worried it'll probably be stupid loud.
Thanks to all and thanks ray for the macgyver tech tip!
Old Sep 20, 2009 | 12:40 PM
bluerice's Avatar
obviously this thread is dead, but i don't understand why it's so hard for companies to make a b pipe that doesn't sit stupid low. Cuz my exhaust right now is just custom 2 1/4" aluminized steel with a 14 x 4" Magnaflow resonator, but i would actually like to get an actual exhaust and if my resonator doesn't hang low even though its about 60% bigger than all the other ones, why is it so hard
Old Sep 20, 2009 | 01:28 PM
dewthedew's Avatar
my megan sits way too low i used clamps to raise it up
eddiec168
Aug 16, 2014 11:08 PM
FITdrummer13
Mar 21, 2012 06:53 AM
SikxChoi
Aug 11, 2011 11:29 PM
beaudet08
Mar 16, 2011 10:21 AM
dewthedew
Oct 9, 2009 04:06 PM
